Question about Microsoft Xbox 360 Console
The screen gos blank and the two red lights flash on the ring. its not overheated and it is well ventilated. someone please tell me what to do
  • 767 Answers
If it takes 1-2 sec for the fan to go to full speed and then two
red lights then the thermal seal has been broken between the
heatsink and G.P.U. or the C.P.U.
Solution
Remove both heatsink . Clean and replace the heatsink compound
and make sure your flush down on the chips with the heatsink.
If this doesn't fix the 2 reds then the thermal couple connection
from chip to board is open and the thoes chips will need to
be re-flowed ( re-soldered)
Rob
Posted on Aug 07, 2010
    Sergeant:
    Champion:
  • 297 Answers
This is actually the sign for overheating and if it does not feel hot it will be the motherboard overheating, you can fix it yourself or send it in to get it fixed.
Posted on Aug 05, 2010
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I am having the infamous Red Ring Of Death issue, ...
Sections 1, and 3 are flashing red
- Overheating
Alternatively Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
May 21, 2010 | Microsoft Xbox 360 Console
During game screen went blank. flashed red ring on 1 and 3
That means your console is overheating. Make sure you are providing proper ventilation (atleast 12 inches in the back and 3-4 on each side minimum) Also make sure that your power brick is not sitting in the carpet as this can cause it to overheat.
Lay your 360 horizontal to give it better airflow and reduce heat in the future.
Dec 25, 2009 | Microsoft Xbox 360 Console
Red ring on console
As you didn’t state how many red lights are on your Xbox i will post all the Red ring of death errors.
All sections red (4 Red Lights) = Could not detect the AV cable. Check all of the cables at the back of the console.
3 Red lights (Sections 1, 3, 4) = General hardware failure. Contact Microsoft Support.
2 Red lights (Sections 1, 3) = Overheating. Make sure that your console is in a well-ventilated area with a good air flow and try again.
1 red light (Section 4)= Hardware failure. This is usually combined with an error code on screen. Contact Xbox support.
Nov 17, 2009 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
Is it possible to fry your xbox 360?
The two red lights is an overheating issue. It correlates with the 3 red lights. First check with Microsoft if your warranty seal is still intact and ask them if its under warranty. also there are some vary qualified technicians who guaranty their work up to 90 days.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Three rings of death
your xbox has overheated i had the same problem to you might wanna contact microsoft
Aug 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
