Question about Dell Dimension 4600 PC Desktop
My cd and dvd drivers were missing. I went to microsoft and ran FixIt they are back . They will read but wont write.
  • 808 Answers
Update driver from some another link & use reginout
Posted on Aug 05, 2010
LITEON DVD/cd rewritable device not reconized
Since the system originally had another version of Windows did you run the Upgrade Advisor and
check the Compatibility Center for the CD/DVD compatibilty (and other devices as needed).
Windows 7 Upgrade Advisor - please run this now.
http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Also check the Compatibility Center (for major devices)
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Check with the System maker and the Device maker for information about drivers for Windows 7.
(BIOS, low level chipset drivers, and other major device drivers).
Check these :
The DVD drive does not function after you install Windows 7 - these are different Sony drives
however the same issue could be affecting your drive.
http://support.microsoft.com/kb/975270/
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/982116
If the System can run Windows 7 AND there are drivers for the devices these might help :
References to Vista also apply to Windows 7.
Stage 1 : Please do all the below even if you have done some before as it is often the total
process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab -
click Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL -
REBOOT this will refresh the default driver stack. Even if drive is not shown continue
below.
Then work your way through these - remember the drive could be bad, could have a loose
cable or slight corrosion on the contacts (usually for a laptop) and other issues.
http://support.microsoft.com/kb/314060 - a Mr Fixit
Manually try this fix if the 314060 Fixit did not work
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs -
a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to
Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista
setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hardware devices not detected or not working - A Mr Fixit
http://support.microsoft.com/gp/hardware_device_problems
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Stage 2 : You could have drive issues as the CD/DVD is actually 4 drives in 1 case ( CD & DVD
burn and CD and DVD read). So it is not unusual for 1 or 2 parts to not function while the others
do so properly.
Did you complete the troubleshooter for the drive that still does not work? There are some
registry entries that the troubleshooter does not fix and those "might" be the cause.
Check with your System Maker and Device maker for both possible firmware updates and the
correct Registry entries for your drive.
These are the keys I think are the ones in question - for the CD/DVD drive sub-keys of course
as there will other sub-keys in these keys. Be sure to ask for specific keys involved as well as
the settings.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware Profiles\0001\System\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
You probably can find more info here and maybe even the exact registry settings for your CD/DVD
drive from someone with the same model.
Forums - a lot of real expert help
http://club.myce.com/
CD/DVD units
http://www.myce.com/storage/
Use DevManView to locate CD/DVD in registry (be careful and make a Restore Point before
changing anything) - find the device in DevManView and then Right Click on it Open in RegEdit.
DevManView - Free - an alternative to the standard Device Manager of Windows, which displays all
devices and their properties in flat table, instead of tree viewer
http://www.nirsoft.net/utils/device_manager_view.html
Hope this helps.
Oct 20, 2013 | Philips Dh-16a3s & Lite-on Dvd/cd...
Tsstcorp cddvdw ts l633p error code 19
Code 19 means there is a driver conflict such as two devices trying to use the same resources.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
Normally the above will fix that issue if not work your way down through these even if you have done
them before.
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
Hope these help.
Jun 14, 2012 | Computers & Internet
CD/DVD driver not working
A few solutions:
1. Have you tried to clean your cd/dvd lens? Probably your lens is getting weak.
2. For advance user: Locate, and then click the following registry subkey:
- Look for DVD/CD-ROM drives and delete the subkey.
- Restart your machine.
3. Let Microsoft FixIt help you:
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Worst case - Get a new CD/DVD-ROM for the replacement.
Don't forget to thumb up! ;) Good luck!
Feb 25, 2012 | Lenovo 3000 Y410 Laptop
Optical drive not recognized by windows
Hi,,,,,,,,,,,,
Do these to clear corruption and repair/replace damaged/missing system files.
Start - type in Search box - COMMAND find at top of list - RIGHT CLICK - RUN AS ADMIN
sfc /scannow
How to Repair Windows 7 System Files with System File Checker
http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
Then run checkdisk (chkdsk).
How to Run Disk Check in Windows 7
http://www.sevenforums.com/tutorials/433-disk-check.html
After the above :
below.
a Mr Fixit
Windows Vista
do so properly.
the settings.
CD/DVD drive from someone with the same model.
CD/DVD units
all devices and their properties in flat table, instead of tree viewer
Hope this helps......
GOOD LUCK.................
Sep 24, 2011 | HP Pavilion dv6647cl PC Notebook
It doesn't work the dvd/cd drive
Here are the solution for Vista/Windows 7
click start button, type device manager in the start search box and hit enter key.
in device manager, click
+ sign next to Cd-Dvd Rom devices.
right click on cd-dvd driver and select uninstall
the driver will be missing
now run the FIXIT software provided in the following weblink
i hope it will fix the issue. if not, you should delete upperfilter or lowerfilter or both in registry editor. steps are provided in the same weblink
Apr 17, 2011 | Toshiba Satellite A205-S7442 Notebook
Cd\dvd is corrupted or missing (driver detectiv)
Download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html and install it in your pc ,once its finished jst restart your pc and see it will work
Jan 19, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Norton 360 install has replaced/overridden DVD drive
Hi, I can certainly understand how you feel and hope I can help.
error 19 isnt necesarily a corrupt driver, it can be 2 drivers trying to use the same resource (as in norton's backup drive and your cd drive, for example)
Try this - Click the start button, right click on "Computer", select "Properties", then click "Device Manager" in the upper left hand corner.
Open the bit that says "CD/DVD Drives" and try right clicking on the drives there and selecting "Update Driver Software". This will probably do nothing. Don't worry, I didnt really expect it to. Now right click on the drives, and select "Delete" and then reboot. This will reset the drivers for ya.
This fix usually DOES work. Most of the time. If it doesnt work, try the ones below.
Hope these help.
Dec 05, 2009 | Gateway GT5435E Refurbished AMD Desktop...
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
