Question about Jacuzzi Cyget In Ground Pool Pumps
My jaccuzi message pump pressure is low - Jacuzzi Cyget In Ground Pool Pumps
  • A Miller Aug 05, 2010
    Not altogether bad ... what is the pressure? Do you have a flow meter? What is the flow rate? What is your filter media?
  • 640 Answers
It could be any one of the following problems. Try these troubleshooting steps for Jaccuzi pool pumps.
1)Pump not primed. Prime pump.
2) Leakage of air into suction system
3)Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5)Plugged basket in skimmer or hair in lint strainer.
6)Dirty filter.
Posted on Sep 29, 2010
How do i change the oil pump on my 2006 Chevrolet trailblazer LT the engine is 5.3
Just because the message says low oil pressure, it does not have to mean that you actually do have low oil pressure. The sending unit could be defective, which could give you a false message. It is quite rare for an oil pump to fail. Check your oil level on your dipstick. If you are down a couple of quarts of oil, the oil pressure could be low.
Dec 01, 2015 | 2006 Chevrolet Trailblazer
Hi I'm having this message, 'low oil pressure' when temp go to suitable temperature my car Peugeot 407
The engine bearing clearances expand with heat which, if excessive, will lower the oil pressure. The spring in the pressure regulator in the oil pump will cause the pressure to drop for the same reason. A partially plugged oil intake screen will work in conjunction with the oil pump to cause it too.
Nov 15, 2015 | 2009 Peugeot 407 2.7
Error code p1041 and p1047 02 chrysler sebring lxi 2.7L
Definition of Diagnostic Trouble Code P1041 Saab: Injector Cylinder 4 Shorting To Ground
There is no definition for DTC P1047
CodeDescription P1192 Inlet Air Temp. Circuit Low P1193 Inlet Air Temp. Circuit High P1195 1/1 O2 Sensor Slow During Catalyst Monitor P1196 2/1 O2 Sensor Slow During Catalyst Monitor P1197 1/2 O2 Sensor Slow During Catalyst Monitor P1198 Radiator Temperature Sensor Volts Too High P1199 Radiator Temperature Sensor Volts Too Low P1281 Engine Is Cold Too Long P1282 Fuel Pump Relay Control Circuit P1283 Idle Select Signal Invalid P1284 Fuel Injection Pump Battery Voltage Out Of Range P1285 Fuel Injection Pump Controller Always On P1286 Accelerator Pedal Position Sensor Supply Voltage Too High P1287 Fuel Injection Pump Controller Supply Voltage Low P1288 Intake Manifold Short Runner Solenoid Circuit P1289 Manifold Tune Valve Solenoid Circuit P1290 CNG Fuel Pressure Too High P1291 No Temp Rise Seen From Fuel Heaters P1292 CNG Pressure Sensor Voltage Too High P1293 CNG Pressure Sensor Voltage Too Low P1294 Target Idle Not Reached P1295 No 5 Volts To TP Sensor P1296 No 5 Volts To MAP Sensor P1297 No Change in MAP From Start To Run P1298 Lean Operation At wide Open Throttle P1299 Vacuum Leak Found (IAC Fully Seated) P1388 Auto Shutdown (ASD) Relay Control Circuit P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM P1390 Timing Belt Skipped One Tooth or More P1391 Intermittent Loss of CMP or CKP P1398 Mis-Fire Adapter Numerator at Limit P1399 Wait To Start Lamp Circuit P1403 No 5 Volts To EGR Sensor P1475 Aux. 5 Volt Output Too High P1476 Too Little Secondary Air P1477 Too Much Secondary Air P1478 Battery Temp Sensor Volts Out of Limit P1479 Transmission Fan Relay Circuit P1480 PCV Solenoid Valve P1482 Catalyst Temperature Sensor Circuit Shorted Low P1483 Catalyst Temperature Sensor Circuit Shorted High P1484 Catalytic Converter Overheat Detected P1485 Air Injection Solenoid Circuit P1486 Evap Leak Monitor Pinched Hose P1487 Hi Speed Rad Fan CTRL Relay Circuit P1488 Auxiliary 5 Volt Supply Output Too Low P1489 High Speed Fan CTRL Relay Circuit P1490 Low Speed Fan CTRL Relay Circuit P1491 Rad Fan Control Relay Circuit P1492 Battery Temperature Sensor Voltage Too High P1493 Battery Temperature Sensor Voltage Too Low P1494 Leak Detection Pump Switch or Mechanical Fault P1495 Leak Detection Pump Solenoid Circuit P1496 5 Volt Supply Output Too Low P1498 High speed Rad Fan Ground CTRL Rly Circuit P1594 Charging System Voltage Too High P1595 Speed Control Solenoid Circuits P1596 Speed Control Switch Always High P1597 Speed Control Switch Always Low P1598 A/C Pressure Sensor Volts Too High P1599 A/C Pressure Sensor Volts Too Low P1602 PCM Not Programmed P1680 Clutch Released Switch Circuit P1681 No I/P Cluster CCD/J1850 Messages Received P1682 Charging System Voltage Too Low P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit P1684 Battery Disconnected Within Last 50 Starts P1685 Skim Invalid Key P1686 No SKIM Bus Message Received P1687 No Cluster Bus Message P1688 Internal Fuel Injection Pump Controller Failure P1689 No Communication Between ECM & Injection Pump Module P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor P1691 Fuel Injection Pump Controller Calibration Failure P1693 DTC Detected In ECM Or PCM P1694 No CCD Messages Received From ECM P1695 No CCD/J185O Message From BCM P1696 PCM Failure EEPROM Write Denied P1697 PCM Failure SRI Mile Not Stored P1698 No CCD Messages Received From PCM P1719 Skip Shift Solenoid Circuit P1740 TCC Or OD Solenoid Performance P1756 Governor Pressure Not Equal To Target At 15?20 PSI P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI P1762 Governor Pressure Sensor Offset Improper Voltage P1763 Governor Pressure Sensor Voltage Too High P1764 Governor Pressure Sensor Voltage Too Low P1765 Trans 12 Volt Supply Relay Control Circuit P1899 Park/Neutral Position Switch Stuck In Park or In Gear
Read more at: http://www.obd-codes.com/trouble_codes/dodge/
Copyright © OBD-Codes.com
Jul 26, 2015 | Chrysler Cars & Trucks
How do I backflow a Jaccuzi pool pump model CFR150-S15TBU9-3-HK6?
**DO NOT** attempt to backwash/backflow a cartridge filter. You will destroy it if you do. Instead, you need to remove it from the canister and wash it per the manufacturer's directions.
Here's a video too:
https://www.youtube.com/watch?v=1N1e0CFDcNo
Jul 23, 2014 | Pool & Spa
OH message showing on sundance spa sentry help!!!
If you are seeing OH and FLO codes, you need to shut it down at the circuit breaker, until it can be serviced. It likely needs a new circulation pump and the flow or pressure switch may be failing to shut down the heater causing the boiling
Aug 08, 2012 | Pool & Spa
I'm trying to find a seal kit for a Emerson spa pump Model #T55MWCCE-1208
The seals are specific to the Jacuzzi pump housing not to the Emerson motor. Most Jacuzzi pumps use the PS-200 or PS-201 seal (some have it listed as AS-20X) here is a Pump Seal Cross Reference.
Jul 25, 2012 | Emerson Pool & Spa
Where could I find a list of Fault Codes for my 3.3 Litre Voyager?
CHRYSLER OBDII DTC
P1101 HCM/PCM Communication Performance
P1103 Turbocharger Waste Gate Actuator Malfunction
P1104 Turbocharger Waste Gate Solenoid Malfunction
P1105 Fuel Pressure Solenoid Malfunction
P1195 Slow Switching O2 Sensor Bank One Sensor One During catalyst monitoring
P1196 Slow Switching O2 Sensor Bank two Sensor one During catalyst monitoring
P1197 Slow Switching O2 Sensor Bank One Sensor two During catalyst monitoring
P1198 Radiator Temperature Sensor Input voltage too high
P1199 Radiator Temperature Sensor Input voltage too low
P1281 Engine is cold too long
P1282 Fuel Pump Relay control circuit
P1283 Idle select signal invalid
P1284 Fuel Injection pump battery voltage sensor out of range
P1285 Fuel Injection pump controller always on
P1286 Accelerator Position Sensor (APPS) supply voltage too high
P1287 Fuel Injection pump Controller Supply voltage low
P1288 Intake manifold short runner tuning valve solenoid circuit
P1289 Manifold tune valve solenoid circuit
P1290 CNG Fuel system pressure too high
P1291 No Temp rise seen from intake heaters
P1292 CNG Pressure sensor voltage too high
P1293 CNG Pressure sensor voltage too low
P1294 Target idle not reached
P1295 No 5 volts to TP sensor
P1296 No 5 volts to MAP sensor
P1297 No change in MAP sensor from start to run
P1298 lean operation at wide open throttle
P1299 Vacuum Leak detected (IAC fully seated)
P1300 Ignition timing adjustment circuit failure
P1388 Auto shutdown relay control circuit
P1389 No ASD relay output voltage at PCM
P1390 Timing belt skipped one tooth or more
P1391 Intermittent loss of CMP or CKP
P1398 Mis-Fire Adaptive Numerator at Limit (PCM is unable to learn the crank sensors signal
for use in preparation for misfire diagnostics
P1399 Wait to start lamp circuit
P1403 No 5 volt feed to EGR
P1475 Auxiliary 5 volt supply is too high
P1476 Too little secondary air
P1477 Too much secondary air
P1478 Battery Temp Sensor Volts out of limit
P1480 PCV Solenoid Circuit
P1481 EATX (Electronic Automatic Transaxle) RPM pulse generator performance
P1482 Catalyst Temperature Sensor Circuit shorted low
P1483 Catalyst Temperature Sensor Circuit shorted high
P1484 Catalytic Converter overheat detected
P1485 Air injection solenoid circuit
P1486 EVAP Leak Monitor found a pinched hose
P1487 Hi Speed Fan #2 Circuit
P1488 Auxiliary 5 volt supply output is too low
P1489 High speed fan control relay circuit
P1490 Low speed fan control relay circuit
P1491 Radiator fan relay control circuit
P1492 Ambient/ Battery Temp sensor input voltage too high
P1493 Ambient/ Battery Temp sensor input voltage too low
P1494 Leak detection pump pressure switch or mechanical fault
P1495 Leak detection pump solenoid circuit
P1496 5 volt supply, output too low
P1498 High speed radiator fan ground control relay circuit
P1500 General alternator 'FR' Terminal circuit fault
P1594 Charging system voltage too high
P1595 Speed control solenoid circuits
P1596 Speed control switch always high
P1597 Speed control switch always low
P1598 A/C pressure sensor input voltage too high
P1599 A/C pressure sensor input voltage too low
P1680 Clutch released switch circuit
P1681 No I/P Cluster CCD/ J1850 messages received
P1682 Charging system voltage too low
P1683 Speed control servo power control circuit
P1684 The battery has been disconnected within the last 50 starts
P1685 The SKIM (Smart Key Immobilizer Module) has received an invalid key
P1686 No SKIM (Smart Key Immobilizer Module) bus message received
P1687 No Mechanical Instrument cluster bus message
P1688 Internal Fuel injection pump controller failure
P1689 No communication between the ECM and injection pump module
P1690 Fuel injection pump CKP sensor does not agree with the ECM CKP sensor
P1691 Fuel injection pump controller calibration error
P1692 Fault in companion Engine control module
P1693 A companion DTC was set in both the ECM and PCM
P1694 No CCD message from PCM- Aisin transmission
P1695 No CCD message from body control module
P1696 PCM failure EEPROM write denied
P1697 PCM Failure SRI (Service Reminder Indicator) mileage not stored
P1698 No CCD message from TCM
P1719 Skip shift solenoid circuit
P1740 TCC solenoid or overdrive solenoid performance
P1756 Governor pressure not equal to target at 15-20 psi
P1757 Governor pressure is above 3 PSI when 0 PSI is requested
P1762 Governor pressure sensor offset improper voltage
P1763 Governor pressure sensor voltage to high
P1764 Governor pressure sensor voltage to low
P1765 Transmission 12 volt supply relay control circuit
Oct 03, 2010 | 1998 Plymouth Voyager
MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V: I'm a new pool user and can't get the pump to prim...
WELL LET ME SAVE YOU FROM THAT JACCUZI .. GET RID OF IT, GET A STA-RITE DURA GLASS.. PARTS ARE HARD TO FIND FOR JACCUZI.. BUT IF YOU LIKE PAIN, YOU MIGHT GET THE LID O-RING AND THE SHAFT SEAL FROM YOUR LOCAL POOL STORE. ASK HOW TO REPLACE THE SEAL AND DO IT RIGHT.. PRIME PUMP AFTER A REPAIR! VOTE IF I WAS HELP ...J
May 17, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Cyget In Ground Pool Pumps Logo
210 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
