Ram proccecor power supply ok vga card ok but no display can u solve it now
    Sergeant:
    Champion:
  • 277 Answers
Wow
there's a contradition there. VGA card ok but no display.
What tells you that VGA card is ok ?
Now if you said , I can go into SAFE mode in my windows but not in regular windows, I would say you may have a driver problem.
Look at your card and write all the info you can find then, google it, and find drivers and do this in safe mode. after installin drivers try to reboot in normal windows
Posted on Aug 05, 2010
No signal to monitor.all connections and videocard seems ok fans work , What can be the problem? send a Trouble Shooting chart please
Okay here are the steps.
1. Turn off computer and restart it with tapping F2, the BIOS screen should come up. 2. If that does not then your computer is not clearing the POST or Video part that comes right after post. 3. Take the video card out and connect the monitor to the On-Board card on your motherboard. 4. If that works then there might be a problem with your video card. 5. If that does not then there is some more troubleshooting to do, try take the memory cards out and see if the motherboard beeps. This is to ensure that it is working fine or not. Put them back in and then try to turn on the computer.
Reply if need more help.
Thanks. If this was helpful, then kindly rate me.
Nov 01, 2010 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
System is on but there is no display
No display can cause by many thing. RAM, LCD, motherboard or any thing connected to motherboard. So, if you have knowledge in this field, you can : - try to take out and put the RAM back to the slot OR you can try with other RAM. If this solve the problem, your RAM problem
Second, you can try plug in VGA cable (connected to external LCD monitor) to the VGA port on the notebook. This step is to check either your notebook can enter windows or not. If the display come out at LCD monitor, means your LCD @ LCD cable problem.
If those thing cannot solve the problem, means either your motherboard or VGA card (for notebook that come with VGA card) problem.
Solution : Send it to service center @ any computer shop
May 09, 2010 | Toshiba Satellite A135-S2276 Notebook
P5p800-mx display problem but power on for this what can i do?
Hi dear, be a professional if you are not, so first of all you should check the RAM(s) and replace them or check it another PC. Secondly, you should check VGA card or graphic card. I hope your problem will be solve.
In the end or last, put away of unplugged RAM(s), VGA card or graphic card if it is not builtin, unplugged all its data cables and main power supply cable and other power connections (with hard disk and cd-rom). Wait for 2 hours and then replace or joint or binding again. It is most possible your problem could be solve if there is problem with your hardware including RAM(s) and graphic or VGA card.
Good Luck
Dec 21, 2009 | ASUS P5P800-MX Motherboard
The motherboard not give any display !
last 2 things to do
1.remove the cmos battery
2.remove the cmos jumper.
remove power cable from power supply.
3.wait for 2 to 3 mins
4.put the jumper back to the correct position usually pin one and pin 2
5.try to start the mb if ok
ok
Nov 13, 2009 | ASUS P5N32-SLI Deluxe Motherboard
Power but no display acer aspire L100
Try these sequence(you need another one good computer to test and interchange component and you will find out the problem):
- check your RAM, if you use two RAM start computer using one and interchange it to find out which one is bad
- if your RAM OK, check your VGA
- if your RAM and VGA OK, try to check your power supply, sometimes defective PS cannot supply sufficient power to all component to work.
hope this will help you.
Jun 07, 2009 | Acer Aspire L100 PC Desktop
Display goes green in colour
remove the ram and wireless card and clean and reinstall and ..........problem is not solve then check the vga port and install and monitor and boot your system and after display is ok then change the display cable........ok
Apr 03, 2009 | Compaq Presario C700T Notebook
PCVRS620G won't turn on
i feel this is not a big problem. if u hear a beep of ram on beap on boot then ram is ok just short it and check for displaay. check ur cpu socket it may be loose. if u don hear a beep on boot change the ram and ur problem will be solved
Feb 07, 2008 | Sony PCV-RS620G PC Desktop
PC can't start, Monitor blank can't show BIOS setting
i can help ya with your problem send me a message i had the same problem tooo awhile ago
Aug 14, 2007 | DFI NFII ULTRA-AL Motherboard
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
