Question about Garden
I painted s front exterior door and now it's stuck closed. how do i fix it?
  • 843 Answers
Use a putty knife (not a sharp utility knife). It is most likely stuck along the surface of the door that faces the street where the door hits the "stop". (The stop is the narrow strip all around the door frame that the door hits when it is completely closed.) Slide the putty knife between the door and the stop all along the edge closest to the doorknob and across the top. (This isn't easy and may take considerable force.) Don't worry about the hinge side. (This will mess up the paint a bit, but lesson learned - don't close the door until dry next time.) If you are really unlucky, the door was also a tight fit along it's edge before you painted it. (The edge of the door is the surface of the door that is only about an inch and a half wide.) If you painted that, and it's stuck there, it may be impossible you are going to have a heck of a time getting a putty knife in there and you may have to force the door open with a prybar between the front of the door and the stop. Good luck.
Posted on Aug 05, 2010
  • 2,100 Answers
Well, first you have to get it open, get the stuck paint cleaned up, then remove some wood so that you can paint it without it hitting the jamb, or was it stuck to the stop? Anyway, when it dries, rub a bar of soap on there, it won't stick again. Hope this helps.
Paint code for 2002 chev tracker exterior trim
It should be in the glove box on that plastic label, if not their try the front door where the hinges are if you still cant find it take your vin number and go to a GM dealer.
Feb 10, 2015 | 2002 Chevrolet Tracker
Can i paint my garage doors?
Clopay's steel garage doors can be painted with any high quality exterior latex paint. Wood garage doors must be painted/stained on all sides prior to installation. Most models are available factory primed. Clopay recommends wood garage doors be re-painted every 1 to 2 years (more frequent refinishing may be required in high moisture areas).
Oct 02, 2014 | Building Materials
How to prep to paint a steel exterior door
Use a sponge sander to send the door and top coated with DTM metal paint it is a water-based product
Aug 10, 2014 | Home
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
I have a problem with an exterior front door. I had undercoated and glossed using stronghold exterior paint after sanding and sugarsoaping. The undercoat went ok ok but the gloss started to wrinkle and...
It sounds to me like you have some bad paint as everything else you are doing sounds good. I would strip it back down, let it dry and try another brand. Good luck. Thank you
Apr 14, 2011 | Home
I am looking for an exterior door panal for
there are two rear exterior door panels for an 06 ION on ebay, possibly is same part, needing only paint to match yours. also look around in the craiglist for your area.
Oct 29, 2009 | 2007 Saturn ION-2 Quad Coupe
1997 buick park ave 4 door right front door handle won,t work from the outside
Order the exterior door handle AND the clip that attaches the rod to the exterior handle from your local dealership ( any part in the salvage yard will have at least as much wear as the one U are replacing ) Also order a can of touch up paint matching your car. After you have the parts and have painted the new exterior handle, roll down the window and remove the interior door panel. ( instructions have been posted at 'replace door lock buttom' ) Two nuts, one on each side, hold the broken handle in place and must be removed ( DON'T loose them ). Loosen the rod from the clip at the top to allow a bit more room, But take note on the way it is attached ( you will need to reattach the rod to new handle ) To install new mechanism put the new clip on the rod, carefully place the gasket and the new handle in place and install nuts to secure. Test the door handle and make sure it works. Reinstall interior door panel.
Jul 06, 2009 | 1997 Buick Park Avenue
Broken exterior door handle,passenger sider ,sliding
Got this idea from mpvclub.com: Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
