Question about Health & Beauty
Scooter stopped dead no elictric was working up till that point
  • 8,404 Answers
Please check all cables to make sure you dont have a broken connection.
Posted on Aug 05, 2010
Does anyone have a maual for a 3 wheeled mobility scooter one with battery between legs by feet.mine stopped working totally dead
try this
search --operators manual for ( you put in make and model) mobility scooter
if there is one available in pdf version , download it
you could go to a shop that specializes in mobility scooters and other equipment for the disabled as many have loan scooters and have a repair facility especially for scooters
Jun 27, 2018 | Health & Beauty
Can I use my scooter in the rain
hi Morag.
Scooter Riding in the Rain Helpful Safety Tips
or this link.
Can use an electric scooter in the rain
Can I use an electric scooter in the rain? Posted on October 19, 2015 by gridsolarsystemOf course,you can.
How to ride your E-scooter in the rain?
The rainy season is here and it is pouring like cats and dogs. Most of the e-scooter drivers have this one common question in their mind and that is how to ride the e-scooter in the rain? Well, it is a valid question and today we are going to find the best answer to it. One of the main reasons why people feel afraid to drive the electric scooter in the rain is because they think that they might get an electric shock. But in actual e-scooters are perfectly safe even when it is raining.
When should you not ride the E-scooter in the rain?
The foremost important point to keep in mind is to make sure that you should never drive the electrical scooter when the visibility is less. If it is a light rain, then there is no problem but if there is a torrential downpour happening, then you should not venture outside on an e-scooter. Lack of visibility can prove to be quite harmful and hence you should make sure that proper care is being taken during heavy rains.
You should also make it a point that if there is a freezing rain happening then also you should avoid driving the e-scooter. If there are snow and rain happening then, there are chances that the tyres may slip.
Excessive rain may cause the chrome on the electric scooter to turn into rust. Excess of moisture may dampen the chrome plating. Typically, this happens if the chrome plating is of low Hence, you should always make sure that high-quality electric scooter is bought and that you can only get from reputed suppliers.
Never drive through standing water
If you see knee deep water on the road, then you should immediately stop. This stagnant water may get into the scooter and can cause extensive damage to the delicate parts. Moreover, water may lead to soil getting soft and your electric scooter can get stuck in the mud and it becomes difficult for you to get if struck.
You should keep this important thing in your mind and that is to make sure that you drive the scooter at a slow speed. Driving at high speed may cause slippages and may result into
Always wear a safety helmet while riding an electric scooter. Though these scooters can only attain a maximum speed up to 30 mph, but this much speed can prove to be deadly during rainy Hence, controlled and slow speed should always be your first priority.
Finally, never let your kids drive electric scooters on their own during the rainy It is for their safety and you must tell them to avoid driving electric scooters on their own during rains.
The real idea behind driving electric scooter is to enjoy the ride and you can only enjoy your ride by staying safe and by following all the safety precautions. Make sure to follow the points mentioned above so that you can stay safe and also enjoy the rainy season on your e-scooter.
Nov 24, 2017 | The Health & Beauty
I have a pre-used mobility scooter. It suddenly stopped dead so hard I slipped forward on my seat. Does this sound electrical? surely if it was flat batteries I would have slowed to a stop? thanks Deb
It sounds like it did an emergency stop. any beeps or flash codes.
Check your user manual for possible causes.
If the batteries do go flat, they get to a certain voltage level and the scooter cuts out for safety reasons.
Apr 02, 2015 | Health & Beauty
My go go elite traveller plus worked fine yesterday took it apart then back together it was totally dead nothing at all
You did not forget to plug in all connection. Or should I say by setting it up again, you did not forget anything?
One cable not plugged in correct, or forgotten, can spoil the fun. Don't assume you did everything right, till you (or someone else) checked everything.
Nov 01, 2014 | Pride Go Go Elite Traveller Plus 4 Wheel...
Engine turns over but doest start ive checked the spart plug its fine the batterys charged an all the elictrics are working petrol and oil is fine ? any ideas
you should first do a full inspection before you try to get it running. If this is the case, I'd do a compression check first because it's easy to do. First, check the quantity and condition of the engine oil. Hook up or purchase a good battery. Leave out the spark plug and crank the scooter for ~5 seconds. This helps to circulate the oil. Let it set for ~15 seconds and then do it again. It's not a good idea to continuously crank the starter because it can overheat and wear out prematurely. Most scooters need a minimum of 100 psi in compression in order to run start and properly. Compression should be checked when the scooter engine is warm. However, that's hard to do if your scooter is not running. So, just hook up a compression gauge and open up the throttle all the way. Crank the scooter until the needle on the compression gauge stops moving. This should take no more than 5 seconds. Very roughly, 100-125 psi is good, 125-150 psi is very good, and 150+ psi is great. If you don't have this level of compression, then you have bad valves and/or bad piston rings. If you want, you can add a teaspoon or so of oil to the engine through the spark plug hole. Then try the compression test again. If compression is higher, then it's likely you have bad rings. The oil will seal the rings and give you better compression. If compression is the same, then you have bad/misadjusted valves.
hope this helps
John
Aug 12, 2011 | Peugeot Sports Vision R3 Motorcycles
My scooter which is a Fold and Go keeps stopping suddenly and battery becomes dead, checked all wiring in battery it seems fine, what other problem could it be?
I had this problem with my caddy. I had to send it to Florida,UPS, and they fixed the problem. It had to do with the tiller connections. Worked great after.
Aug 09, 2010 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Schwinn S400 no power
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are probably available at:
http://www.electricscooterparts.com/schwinnscooterparts.html
Jun 17, 2009 | Transport Schwinn Rechargeable Portable ...
I own a pride mobility scooter with an issue of stopping
It could be a loose battery connector and the controller heats up when it's trying to pull amperage out of the batteries but can't because of the loose connection Try tightening bolts on batteries but disconnect them first. Also it could be the brake on the motor and if the unit isn't shutting off the lights on the tiller blink in patterns to let you know what problems to check for.
Feb 26, 2009 | Hurricane Pride Pmv Mobility Scooter Candy...
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
