Question about Vehicle Parts & Accessories
I need to replace the red LED warning light on a Toad alarm. Does anyone know the correct voltage? I have tried a12v led and it is very dim.
    New Friend:
  • 103 Answers
It is a standard 3 volt LED.
Posted on Aug 14, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
What can you advice me to do? i have a UPS SURTD5000XLI, indicating a red Led light, but when i remove it from the AC power source, the Red Led also remove & when i flog it again to the AC Source it...
Is red light on for overload or for battery?
If on overload, try reducing the load on the UPS. If red light on overload persists buy a new UPS (overload fault hard to repair).
Red light on battery - replace the batteries.
Red light on boost or buck, may mean that the nominal voltage of ups and the limits need to be changed/corrected.
Jun 23, 2014 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
The alarm isnt working... car wont start, buttons wont work!
Just a possibility, but a discharged battery could be the culprit. Do the headlights come on brightly? Will the horn blow normally? A 'dead' battery will usually have enough power to illuminate LED warning lights, while not having enough current to operate the starter/door solenoids, etc. Have somebody test the battery voltage to be sure.
Mar 14, 2017 | Toyota Corolla Cars & Trucks
Blinking red and yellow light
Generally if both the (red) alarm LED and the (yellow) data LED are both blinking, it is an indication that the tone cartridge needs to be replaced. You should be close to out of cartridge.
Jan 12, 2009 | Brother HL 1440 Laser Printer
Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Jun 08, 2008 | Sanyo PLC XU35 Multimedia Projector
Vehicle Parts & Accessories Logo
396 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
