Question about Ovens
How to set machine and how to operate digi DI-81 weighing balancer
How do i set the clock on Whirlpool built in double oven? Can't find a model number. 5 buttons from left to right. Alarm bell, clock with hand at 12, clock with hand at 3, + and - signs. Pleas
The model number is usually located on the side of the door or on side of the oven cavity area near the door opening. Sometimes if you have a drawer or warmer the model number is located on the oven side of the drawer or warmer (sometimes not directly facing you but on the side of that area. If the oven is electronic you press a clock button or you hold one of those buttons for a couple of seconds like a start or set button. The model number though will help you find a user manual and it for sure should be clear. I hope this helps you.
Nov 16, 2014 | Whirlpool 24" Double Electric Built-In...
One tablespoon is equal to how many grams?
Tablespoon is a unit of volume, gram is a measure of mass (or weight).
One tablespoon of water weighs about 14.8 grams. One tablespoon of gold weighs about 290 grams.
Mar 12, 2014 | Ovens
How many grams in one tablespoon?
That's an impossible to answer question. A tablespoon is a measure of volume. A gram is a unit of mass. In other words, a talblspoon of water may weigh in the neighborhood of about 11 gms, While a tablespoon of gold would weigh close to 200 gms.
Control panel light is extremely dim
Should be C3 Capacitor on control panel board replace capacitor from Digi-key Corporation get panel out and see what C3 capacitor says what voltage and uf and temp celcius and order from them solder it takes two -10 minutes..
Apr 19, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
I have St. George Imperial Fan Forced Oven with Griller (Wall Oven) SGW FO need measurements and specs also model number ?? Can someone please help me have been looking on net for ages...Getting...
you should find the model number between the bottom of the griller door & the liner .. silly place really to get at... as you cannot remove the grill door as you can the oven door.
we have just rebuilt one from two we acquired ... best oven ever .... there will be a few different models as these were produced & cosmetically changed over a 20 yrs period. Ours now looks like a brand new oven as they are REAL baked enamel ... you can clean with caustic based product without any harm.
I am searching for a manual if anyone has one mine is 67/wdl.v.81.fo I presume the 81 in the number denotes 1981 manufacture.
Don't be fooled if you find the oven does not heat at some stage & everything else works ... this is usually after a cleaning & the auto on & off timer has been activated ...just a matter of setting back to manual mode.
Hope this helps although you have probably solved by now having posted in April 11.
Anyone have a manual for this model would be appreciated .
Apr 16, 2011 | Ovens
What temperature di I put my self cleaning oven on for it to clean?
When you start the self cleaning the oven will automatically lock the door and set the temp. all you have to do is set the time you want it to clean for.
Mar 12, 2011 | Kenmore Ovens
I need an instruction manual for a red centre outdoor gas oven
Instructions Things You'll Need:
  • Power supply
  1. Press the "Clock" button, then the correct number buttons to set the desired time. Press "Clock" again to confirm.
  2. Press "Timer" to set the timer function. Choose the desired countdown time by pressing the number pads, then the "Start/Stop" button. Press "Timer," then "Reset" to cancel the timer.
  3. Press the number pads to select a cooking time. Press "Power" to use a power less than 100 percent using the number "9" for 90 percent of full power, "8" for 80 percent, "7" for 70 percent, and so forth. Press "Start" to begin cooking.
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. Enter the weight of the item, then touch "Start" to begin. Enter the food weight by pounds and ounces, using a "0" for a decimal. For instance, if the food weighs 1 pound, 2 ounces, enter "1," "0," "2," then "Start".
  5. Select "Speed Defrost" to defrost food quickly. Enter the desired cooking time and press "Start."
Dec 21, 2010 | Ovens
Ovens Logo
108 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
