Question about Car Audio & Video
2003 Pontiac Montana extra length,luxery Replaced radio with RDS with same model from a different car, radio locked up
  • Car Audio & ... Master
  • 32,281 Answers
Car radios in most cars are protected with a security code. If you remove the power cable from the battery or remove the radio from the car and insert it into another car, you need to enter the security code to get the radio working again.
The security code is supplied with the car manual when the car was first purchased.
You need to contact your car dealer or Pontiac with proof of ownership, model and serial number to get the secutity code.
Posted on Aug 05, 2010
How do I repair the antitheft system after jump starting my 2003 Pontiac Montana?
try using a fault scanner to reset the CPU program in the ECM
Jan 26, 2015 | 2003 Pontiac Montana
Wondering if I can change the starter on my 2003 Montana with a starter from a 2002 Montana?
PUT A BREAKER BAR ON ENGINE CRANKSHAFT BOLT AND SEE IF YOU CAN GET THE ENGINE TO TURN OVER BY HAND,IF IT WONT TURN, SOUNDS LIKE SOMEONE SOLD YOU A EHICLE WITH A LOCKED UP ENGINE. GOOD LUCK!!!!1
Jul 21, 2013 | 2003 Pontiac Montana
Changed rds radio;but can't get used 1 to work?
most of the radios have a security code that has to be programmed to unlock the unit. the code is available at radiocodes.com but you'll need the serial number off the unit you are installing.
Jun 09, 2012 | 2003 Pontiac Grand Am
My 2003 pontiac montana keeps over heating
Check your catalytic converter..It's before the muffler..See if it's getting extra hot...That will make your car motor very hot.
Dec 06, 2017 | 2001 Pontiac Montana
2003 pontiac montana key wont turn first time this
the tumblers in the ignition cylinder is jambed.
replace the lock cylinder to fix this problem
Feb 07, 2010 | 2007 Pontiac Montana
Gm unlock codes for factory rds radio. it has cd
There is a code to get from the radio, then a Technicians will call GM to get the actual unlock code. Only takes a few minutes.
See this link to do it yourself. They have a 1 hour turn around...
GM Radio Unlock Codes
Nov 12, 2009 | Car Audio & Video
I need the Theftlock radio unlock code for a 2000 Pontiac Montana
it aint working dude because you have a RDS radio, that means your radio transmits data, like when it shows the song and the title of whoever sings it, your screen dont say LOC, IT SAYS LOCKED, YOU HAVE TO TAKE IT TO A DEALER TO GET IT UNLOCKED, THEY USE A TEC 2 DEVICE TO DO IT. Thats why those steps dont work, i gurantee it, because i got a 2003 pontiac grand am and had the same problem.
Jul 12, 2009 | Vehicle Parts & Accessories
2006 gm rds radio is locked need to unlock it
I have a 6 disc AM/FM RDS Radio from a 2003 Chev Suburban that I purchased used and installed it into my 2003 Chev.Silverado and it went into lock up after I Installed it.How do I unlock it
Mar 29, 2009 | 2006 Chevrolet Silverado 2500HD 2WD
Radio Code
I believe you have another problem, because the radio will keep the calibration of the radio as long as it stays in your van. it will only lock if radio is swaped with another pontiac radio. to unlock it you will need a GM tech II to recalibrate the unit.
Dec 14, 2008 | 2001 Pontiac Montana
How to put out the radio in montana 2003
there are 4 screws. two in the front behind the cup holder and two up underneath in the cupholder bay after the cupholder is removed. they are phillips head and 8mm I believe. this is all you need to remove the cover.
Dec 12, 2008 | 2003 Pontiac Montana
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
