Question about Philips HDD120 MP3 Player
Hi there, i got a Philips HDD 120 !Like 20 minutes ago i have transferred all the music from my pc in my Mp3PLayer (Hdd 120) and after 1 minute it suddenly blocked ! I can see the last 2 Links : All Tracks - and - Recordings ! and the other half of the screen is Blank ! i have tried to restart it , but i can`t !!! I think it`s gone ! I have crushed it like 10 times on the floor but it still , does`t work:D Can someone tell me what to do ! Thanks !
SOURCE: Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Posted on Oct 29, 2007
SOURCE: Philips HDD 120 MP3 Player
try using this prog http://herbert.steperry.co.uk/downloads/?download=1.0 I have working on MS XP no problem, and a little easier to use than the bundled software
Posted on Nov 25, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Philips HDD 1630 won't charge
In some cases, it is possible to save the GoGear when it is displaying the symptoms you describe. IMPORTANT: First, back up all music and other files stored on the device. The process I am about to describe will delete all files from the GoGear. Also, this is not a GUARANTEED solution - it works in many cases, but sometimes the player will need to be replaced ( replacements/repair svcs are not necessarily available from the manufacturer).
1) Connect the GoGear to the computer
2) Open Philips Device Manager (Start --> All Programs --> Philips in Windows XP if no shortcut on desktop)
3) Click on the Repair tab - see if there is a msg that says something like "to repair your player, connect GoGear to computer while holding the volume + button"
4)IMPORTANT: Disconnect the GoGear from the USB cable, turn the GoGear OFF, and then press and hold the volume + button; then, connect your GoGear to PC while still holding the volume + button (VERY IMPORTANT: this process will fix your player, but it will also delete all music and images you have stored on the GoGear) - do not let go of the Volume + button until a pop-up comes up saying that your player is being repaired
In some cases, there is a small anomaly that is preventing the charge from getting to the GoGear. This repair process can save GoGears that were seemingly hopeless. However, this solution is not guaranteed to work every time. Also, to prevent this issue from happening in the future:
a) make sure that you are using a computer with Windows XP
b) this player works best with Windows Media Player 10 (so rollback if you have WMP 11 - or get a newer model GoGear)
c)get the latest firmware upgrade for this device from the Philips website - it has been known to fix some scattered issues with the HDD1630
-ThaMp3Doctor
Posted on Feb 04, 2008
SOURCE: Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Posted on Mar 15, 2008
SOURCE: philips dvdr3455h/37 recording issues
I was having the same problem if I used DVD+R blanks, but the programs would record fine if I used Memorex DVD+RW rewritables. Until today, that is - now it won't let me burn anything from the HDD to a disk!  My 3455H is about two years old.
Gotta say I'm quite disappointed with it, and would never consider another Philips product. :(
Posted on May 06, 2008
Password bios hp 2000-2a10NR
hi
try to remove the cmos battery and the main battery after 10 minut go to bios if the password is there you may have pasword also in the hdd.
then you have to reprogram the flash rom.depend what pasword you chosen.usually the cmos battery removal works
Mar 20, 2013 | HP 2000-2a10NR AMD E1-1200 1.40GNotebook...
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
IBM THINKCENTRE A51p WIN XP PRO/SP3 1GB RAM ALL MICROSOFT UPDATES ARE CURRENT BOOTS QUICKLY WITH 1 SATA HARDDRIVE (1.5 MINUTES) BOOTS SLOWLY WHEN 2ND SATA IS ADDED (5 MINUTES) ONCE WINDOWS...
it seems as they are conflicting this u usually caused by jumper settings you need to download the utility program from the hdd manufacture the utility allows you to change hdd priority you need to change the settings on the second hdd to slave and the first hdd to master but like i said unlike ide which has jumpers sata has digital jumpers the utility from products website is needed for this
Sep 02, 2010 | IBM ThinkCentre A51 PC Desktop
When i start up my laptop it says that it cannot find internal hdd when it was just woking 20 minutes ago
#1 Reseat the hard drive (Sometimes the connection works loose) #2 If reseating doesn't work, HDD may have failed.
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Boot problem thinkpad r50e
Your PC may be doing a complete memory check, this does take time although your 1 minute boot time might make some of us jealous.
Check your BIOS settings to see if you have a 'Fast Boot' option. If it does, make sure you are using it. It then will make only a cursory check of memory and it is probably OK otherwise you would have other symptoms that would let you know.
Dec 31, 2008 | IBM ThinkPad T40 2379 Notebook
Audio is out
Hi, try this:
Reset the whole machine by doing the following (this will not erase your HDD by the way):
1. Turn off at wall for 5 minutes
2. Turn back on at wall WHILE holding the standby/on button on the front until the front panel display goes black.  The recorder should then be left for a few minutes and then turn it on on remote, when the machine should prompt for language, time and date and work normally again!
Dec 31, 2008 | Philips DVDR520H DVD Player/HDD
Cant put tracks on gogear as musicmatch not compatable with vista help
Try transferring with Windows Media Player instead - see if the GoGear icon appears on the left hand side of the WMP screen (while the GoGear isp lugged in). If it does, then you can transfer and delete songs through Windows Media Player.
-Tha Mp3 Doctor
Jan 23, 2008 | Philips HDD065 MP3 Player
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Adding tracks to library
  1. Make sure that your hdd is connected to the power supply with the AC/DC adapter. Launch the Digital Media Manager DMM application on your PC.
  2. Click PREFERENCE to enter the preference menu, click BROWSE to select the folder where you keep all your music files. Click OK and then DONE to get the music into the library.
  3. Click EASY UPDATE at the bottom of the Library/Device view to activate the easy update screen
  4. Click the UPDATE LIBRARY or UPDATE BOTH icon to transfer new content from the music library of your computer to the hdd.
  5. Once the update finish you may click on the removal icon on the task tray to stop and eject the jukebox. When a message saying the USB device can now be safely removed from the system appears click OK.
  6. Unplug the hdd from PC and enjoy your favorite music on the move.
Jan 02, 2008 | Philips HDD120 MP3 Player
The music transfurs but there is nothing showes up in my playlist
You need to transfer the music using a program called musicmatch which is available from the philips website. These philips players are awkward like this. Hope this helps
Dec 09, 2006 | Philips HDD070 MP3 Player
Philips HDD120 MP3 Player Logo
123 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
