Question about Microwave Ovens
Can i run my daewoo microwave without a food splashguard
  • Microwave Ovens Master
  • 9,098 Answers
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
If your waveguide cover is burned, damaged, or missing, it will need to be replaced.
Its job is to protect the magnetron from being damaged due to grease or food particles.
The metal behind the cover should be cleaned with a mild, non-ammonia cleaner before installing the new one. The metal edges of the oven behind it can be sharp, so be careful!
Please reply back with your brand and full model number or visit https://www.mcappliance.com/partorder.aspx or http://www.e-daewoo.com/customer_service.asp.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
It is a Daewoo MicrowaveThe microwave does not heat up the food! It is only about 18 months.Tried to to re_set but nothing happens as the food remains frozen or cold!Anybody has any suggestions?
There are three parts that could be bad. One is a high voltage diode, another is a capacitor and the third is the magnetron itself. If you are not familiar with these terms, it is time for a new microwave oven.
Oct 21, 2016 | Daewoo Microwave Ovens
MY DAEWOO MICROWAVE KOR 1B4 H JUST STOPPED WORKING.
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Dec 01, 2015 | Daewoo KOR-1B4H Microwave Oven
My microwave oven model kog-134k is not heating food, otherwise its functioning well.
The problem is caused more than likely by a defective magnetron, "heats food" because it is the heart of the microwave oven it is the most expensive to replace, it is cheaper in the long run to buy a new unit rather than have it repaired.
Jun 19, 2011 | Daewoo Microwave Ovens
Daewoo koc-985t bi - Not heating food equally. ie. middle of food cold. Sometimes food takes double the time to warm.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Daewoo KOC-925T Microwave Oven
Microwave sparks inside oven in the area of the sealed compartment when it is started
If unit was run for long time with food on walls and not cleaned off, it is possible that the unit was burned in a spot where the food was and if there is metal frame under that part for the finish it will spark. Check closely for burns, if it is sparking due to that problem, junk it. It is a dangerous condition.
Jul 28, 2010 | Daewoo KOG-867T Microwave Oven
Arcing while cooking.
Make sure the inside of the oven is clean and the waveguide cover on the right wall of the oven is especially clean and not damaged. Don't ever run the oven without food in it. If the waveguide cover is damaged it will arc no what but you can probably get a replacement for a few bucks. The magnetron may already be so damaged that it'll never work right again.
Oct 19, 2009 | Daewoo KOC-925T Microwave Oven
The microwave of my daewoo koc-975t does not heat the food.
it is either the magntron or the transformer they are both expensive
Jul 15, 2009 | Daewoo Microwave Ovens
Daewoo over the range microwave model KOT-21OUB just stopped working for no apparent reason. Lights and fans still work. Not heating food. Worked for one dish then the next nothing.
how old is the machine, microwave ovens have a tendancy to do the ridiculous for no possible reason. a check of the main power fuse within the unit might help. it is a large fuse 10A> that supplies the transformers
Feb 17, 2009 | Daewoo KOR-630A Microwave Oven
Daewoo microwave problem
The Daewoo model # is WM 1010CC.
The unit blows a fuse every time I open the door to get food out.
Please suggest a fix!
Bart Gibbons
Nov 03, 2008 | Daewoo Microwave Ovens
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
