Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
This device cannot start. (Code 10) my pendrive is not working
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Kodak easyhare software won't download invalid calling object
just click the red button "share" on your camera, then disable sharing, if you have the device connected to a computer, automatically it will open the content of your camera as if were a pendrive or an external hdd, problem solved.No need of kodak addon software.
Jun 14, 2013 | Cameras
Hello my transcend jf v30 16gb pendrive is not working. when i plug in to the pc it detects the pendrive but cannot acces the pendrive,a window comes out to format the pendrive and when i format the...
hmm raw file system it seems like it does need formatting however try doing so in disk management (right click start menu and click disk management if in windows 10 if not go to control panel and go to admin tools then double click on computer management inside the program you can find disk management)
Aug 22, 2017 | Computers & Internet
When ever i insert my 2gb pendrive on any computer it doesnt work i have my imp data inside tat, and it always says"device cannot start code 10"
your pendrive have some software problem....
search transcend service center in nearest places by internet and do the procedures...........
Jan 22, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My 4 GB V30 Transcend pendrive is not getting detected in any OS (linux and windows 7). In windows its saying that driver software installation failed. And in device manager its coming as unknown device....
try to open in another computer see if it opens there n get ur data first coming to the unknown device issue, firstly insert ur pendrive to usb slot firmly then refresh your comp for about 5 times wait till the drivers are installed open "my computer" n see if the pendrive icon is displayed if its displayed double click n start using . If the above procedure does not work first time do repeat it ur pendrive will work for sure
Sep 20, 2010 | Transcend (589307) Media
When i plug in the pc they cant show pendrive
go to my computer properties>hardware tab>device manager and uninstall
all usb controller devices
this should unisntall all corrupt drivers and restart
then plug the device this should fix it
incase this does not work try to plug the usb on a different computer
If the usb is not detected on a diff computer it may have been damaged
tell me if any issues
Feb 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb problem
There is no repair options for transcend pendrives.You can try formatting them, by right clicking on the device driver and selecting format option.Press start and the pendrive is formatted.Also the data in the pendrive will be deleted.Generally if the device is not being detected, then the pendrive can be claimed for a lifetime warranty.
Jan 19, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive not working
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and click press Enter. It should open Device Manager.
5. Click View. Click Show hidden devices.
6. Click "+" to expand "Storage Volumes" and right click on everything that is under Storage volumes. Also, expand Disc Drive and uninstall everything present under this apart from your Hard Disc (Please make u dont uninstall Hard Disc)
7. If there any unknown devices right click it and click Uninstall.
8. Reboot the computer.
If this does not work please let me know.
Thanks
Nov 14, 2008 | Transcend (589307) Media
Usb port ceases to work when any device connected to second port
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Jul 29, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Pen drive problem
hi.
Vista doesnt recognize all pen drives. only few like Sandisk, Transcend etc get recognized. Even brands like kingston don't get recognized. so to make them work install the driver for the pendrive. If you specify the brand of your pen drive ..i will try to help out with a driver .
regards
bzoy
Dec 11, 2007 | Transcend (589307) Media
Electronics - Others Logo
309 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
