Hi team in order to remove and replace the drum bearing should i atempt to seperate the two halfs of the washing machine and if so what and where can i obtain any diagames or information that would assist me Many Thanks Terry Maher
  • 343 Answers
No model or brand supplied...
To replace the bearings, you'll have to be able to get the shaft out.. This is part of the inner drum and should probably be changed along with the bearings and seals.
By all means have a go at replacing the worn components, but you'll probably find that unless you replace everything you won't get a long life from the overhaul.
In fact, paying to have a workshop job done is probably worth the extra. You'll have a warranty, and (hopefully) a professional job which will give you good value for money..
There are a lot of things which can effect the life of the components in a rebuild..
Check the price of a new machine.. You may be surprised!!
Get quotes.
Good luck....Nomess
Posted on Aug 07, 2010
Replace bearings in drum
If this is a front load washer, replacing the back drum bearings is probably not worth it cost and time. It usually requires a complete strip down and removal of the complete outer tub and drum assembly.Once removed the outer tub has to be split in half to remove the spin drum. Rear bearing is sometimes part of the back half of the outer tub so that half will need to be replaced and possibly the rear shaft on the back of the spin basket. I have done a few and it takes 2 techs and about 4 or 5 hrs to do the complete job. Only worth the time and parts if still under warranty.
May 12, 2015 | Washing Machines
I need to replace drum bearing but canot seperate the drum
Hi
Please see the video to replace the drum bearing---
Hope this helps...please post back for further assistance.
Daniel
Jan 24, 2011 | Hotpoint Ultima WD72 Front Load...
How do I change the drum bearings?
The only 100% solution is to replace the whole rear tub half complete with bearings, you may also need to replace the drum shaft as well, because any slight wear on it will lead to premature falure of the bearings.
Nov 21, 2008 | Zanussi F1045W Front Load Washer
How do i change the bearings
Hi.
Have you managed to sort out your problem?
If not let me know, and I will tell you how to proceed.
Cheers.
Oct 25, 2008 | Hotpoint WMA64 Front Load Washer
How to change bearings
how can i remove the drum or bearing
Oct 25, 2008 | Washing Machines
Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Sep 27, 2008 | Hotpoint Washing Machines
Hotpoint WM A54
about the same level of difficulty as zanussi. however on some wma series the bearings are not available seperately - new drum and tub- so check first
Sep 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Bearing noise
You have to remove the outer tub assy from the cabinet then split the halfs, We're told the the bearings are part of the rear tub housing. You might be able to press out the bearings
Feb 11, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
