Question about Kitchen Ranges
When turn oven on GE XL 44 Gas Stove bottom of oven does not get hot. However there is an orange glow coming from bottom of oven under the shield. What do you think it could be? Broiler works fine. Thanks Steve
  • 135 Answers
The glow that you see is the electronic ignitor. If it is glowing and not getting hot you will need to replace the ignitor. It is not strong enough to open the gas valve. They grow weak over time.
Posted on Apr 26, 2008
My GE XL 44 oven will not come on
Does the igniter glow white hot when you try to start the oven?
Apr 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge xl44 gas range ..all of a sudden the oven does not work...eveything else does... do i need someone to come out? HELP...
Probably just a weak ignitor. Fairly common on these. If you can change a spark lug you can change an ignitor.. These get weak and dim. if yours comes on but is dim orange it is weak and not allowing the bi-metal to open. If yall bump the stove and the oven comes on that is another sign of a worn out ignitor:
GE XL-44 stove service manual
How it works: Silicone carbide ignition
A tip by TheMobilian
Apr 21, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
GE XL 44 Kitchen Range
replace the ignighter bar in the lower oven pull the racks out remove the two screws in the oven bottom pemove the panel under that remove the metel flame spredder the ignighter is at the back of the burner bar get your model number and go to appliance parts store for a new one and follow inst even if it glowes doesnt mean its good it should light the oven whithen 30 seconds
May 24, 2008 | GE JGBC20 Gas Kitchen Range
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
Oven won't light
Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
Nov 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
163 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
