Question about Hitachi Televison & Video
Lamp light still flashing after lamp replacement on Hitachi 42v715 model lcd tv
  • 1779 Answers
SOURCE: My Hitachi 70" LCD will not turn on
Take the door back off and look for a safety tab somewhere on the door that will activate a small safety switch, the tab will stick out. Maybe you broke the tab off or just didnt get the door on correctly. Try that and let me know.
Posted on Feb 04, 2009
  • 133 Answers
SOURCE: Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Posted on Jan 09, 2009
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
SOURCE: hitachi tv LCD blinking red light tv wont' turn
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Posted on Oct 30, 2010
42v715 how to replace lamp
new lamp ,USD130
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Aug 17, 2012 | Hitachi Office Equipment & Supplies
Hitachi 42V515 LCD TV
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 12, 2008 | Hitachi 42V715 Rear Projection Television
Hitachi
Mine did that and the red light was flashing it was the lamp. Best place to get one is ebay
Aug 03, 2012 | Hitachi 42V715 42" HDTV
Hi I have a Hitachi Ultravision Television Model No. 42V715 I have a steady lamp and no picture or sound. If the lamp is my total issue, where can I find a lamp and is it easy to replace myself?
Go to Hitachi.com and put in the model# of your tv. The manufactruer has made it to where you the comsumer can change the lamp yourself. Use a vacume to clean out any dust. Hope this helps.
May 25, 2011 | Televison & Video
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
Hitachie 42v715
The lamp is dead.The lamp in the tv now,been in used 1 1/2 or 2 years?The lamp life span is over.
May 16, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Power light is on, temp light blinks, and lamp light blinks, no picture.
Its possible that your lamp is bad, or you have not closed the lamp cover properly. If you don't close it, the sensor will tell the TV not to turn on.
Feb 04, 2010 | Hitachi 42V715 42" HDTV
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Televison & Video Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
