Question about Indesit Dryers
Ive replaced interlock and machine is not workin anymore why is that, was workin before
    President:
  • 2,702 Answers
Is the door cut off lock adjusted right
Posted on Aug 05, 2010
Will not shift out of park
On the right hand side if the gear selector is a black cover you can remove it with the tip of a key. If you have one insert a key or something that can push that button in there, it over rides the shift interlock mechanism, You have a shift interlock failure this can be from a brake switch or the solenoid itself
Mar 14, 2012 | 1995 Kia Sephia
The car wont come out of park
The problem is with the shift interlock switch...the device which prevents the transmission from being shifted out of park without the brake pedal pressed. The switch is usually located somewhere under dash near steering column on column shift models and under the console on floor shift models. Have it replaced.
Jun 11, 2010 | 1995 Oldsmobile Eighty Eight
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Indesit wie157 washing machine. led displays error code "door", ive bought a new interlock and replaced it but it still wont work, what is wrong? thanks paula
Make sure the door is positively latched in.,some times a weak or broken door spring or striker is the cause of the problem, if you are satisfied these are o/k, then it is probably a control board problem, and you will probably have to call an engineer.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Machine won't turn on
Display error E40 is normally associated with interlock problems and this covered in your manual.
The interlock light should be on when the power switch is pressed and stay on till end of program?
It is not difficult to replace the door interlock.Remove machine top cover.Look inside and locate the door interlock and wiring. Remove as many plastic ties as necessary from the wiring to assist removal, also trace and make note of plugs you will need to pull of. Once you have unplugged the wiring harness open the door and remove two screws and bracket that secures the door interlock. Now carefully reach down and remove door interlock taking care not to pull other wiring in the process.
Sep 01, 2008 | Zanussi FJS1225W Front Load Washer
Black ink problem
It could be also the clogging of nossels in color Balck?!
For this purpose you need a special Cleaning solution, wich you
put first in the balck cartrige and start 2x cleaning(when cleaning you should observe if the balck ink is realy transported through the tube !!).Then you shut down your printer for about 24 hours.After that you clean also
for 2x times and check after that the nossels printing test. If not all nossels are free you should repeat the hole thing once again....till the nossels are free.Another problem i observed at my printer is that at some CISS ore kompatible cartriges the rubber-sealing get used with the time and do not seal enough the
conection from cartrige to printer-head and they **** only air...
For this problem i sugested a solution ..see epson stylus 1400
i hope i could help
Apr 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Bobbin
I have the same problem, how do I retime my sewing machine
Oct 24, 2007 | Sewing Machines
Dryers Logo
59 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Marvin
Marvin
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
