Question about Whirlpool GEW9250 Electric Dryer
Dryer not drying My dryer is heating and venting but clothes are not drying.
  • Whirlpool Master
  • 8,220 Answers
CheckDryer not drying My dryer is heating and venting - 7f91313.jpg Nice manual about dryer venting
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
  • awm1964 Aug 05, 2010
    I completely cleaned out the dryer vent line and all of the places I could find lint accumulating. I have done a little bit of internet research and think the next step will be to replace the sensor bar.
  • Dan Webster
    Dan Webster Aug 05, 2010
    Autodry VS electronic sensing: First, wet clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum. (Auto dry dryers utilize a system of cycling the timer motor with the element, and has nothing to do with how wet the clothes are by the way.) There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out the board and clean the contacts that sometimes is all it takes) Address the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel on many models. No sensing bars means you have auto-dry a totally different animal. Typically an orange wire is connected to the high limit on the heater element housing which feeds the timer motor when the element is not in operation. Bad control thermostat or air restrictions are the Autodry type dryer's worst enemy. Special thanks to a.g.
Dryer not heating properly
More often When you experience a problem like this with your dryer it is becouse of a clogged dryer vent hose or the vent in the wall. Disconet your dryer vent hose from the dryer to see if it will dry properly. Then you will know if the dryer or the vent.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Maytag Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer want heat
If the dryer is heating but not drying it is because of a clogged up dryer vent so disconnect it from the back of the dryer and if clothes dry then your vent is clogged and needs cleaned or replaced. please rate me
Jan 09, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
217 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
