Re xerox f 110
I thank you for your response but i could not open the attachment so i still not sure how to reset the main memory. it would be greatly appreciated if you cuold resend the information thanks for your help
    President:
  • 2,072 Answers
Been trying to E-mail you a manual but your E-mail address is rejecting my attempts.
Posted on May 06, 2008
Xerox 4510 RAM Error
Did you use OEM Xerox memory? Xerox is notorious for not working with 3rd party memory. If the memory is not the error, the problem will be the main board, part number 960K41801
Sep 16, 2014 | Xerox Phaser Office Equipment & Supplies
Tip
Hi Viper, Thanks for the tip. I'm having the same problem with my Xerox...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 14, 2008 | HP PSC 1610 All-In-One InkJet Printer
Xerox c123 error 116-389 problem
The error 116-389 signifies "'read-only memory not install ", or read-only memory not recognized.
Reseat the memory.
if it does not clear, your memory is bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | Office Equipment & Supplies
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 16, 2010 | Xerox Office Equipment & Supplies
Xerox 4800 one touch flatbed scanner
Uninstall drivers and remove usb cable.
re-install drivers without usb attached.
Reboot and attach usb cable
Sep 17, 2009 | Xerox One Touch 4800TA Flatbed Scanner
Copier is a 214 and shows U6 code
A U-6 means the memory on the main board failed.
If the machine is old, the battery on the board is old and not holding the values in the machine.
Replace the main board will correct the problem.
Since it is in the middle deep in the machine you might need to have Xerox repair it for you if they still provide service to this model.
Good luck.
Sep 06, 2009 | Xerox 212 Laser Printer
Machine display Full memory messege. Idone what
On this fax machine if you tried everything and still no luck, you might want to try to reset the main board.
This will reset the main board to factory settings.
When you do this, you may need to enter all your information back in again, speed dials, date, time, ect....
On this type of problem, sometimes this works, sometimes the problem maybe more indepth such as, replacing the main board on the machine. I am talking about the large mother board.
Hold down these buttons at the same time... Menu, 1, 3 and * button.
While holding these buttons, use the left hand to power on the machine, while holding these buttons for about 15 seconds...
When you let go of them, the machine should come back on to a normal screen.
There can be other changes in the memorywhen you reset the main board information.
If the machine does not come back on to a normal messege screen, you may need to replace the mother board.
Good luck.
Sep 03, 2009 | Xerox WorkCentre Pro 765 Laser Printer
Memory fills after entering one number for manual group send
Ok, whatever is in the memory, you can clear it all out by resetting the main board.
If you wish to do this you can try this.
If i remember,,,,
hold at the same time 1 3 and # at the same time, hold them.
With the other hand power on the machine while holding the buttons....
hold them for about 10 seconds.
let go, and power off the machine.
power on the machine see if the memory messege went away.
If not, try holding the 0 button instead, or in a different routine hold the * button. this will reset the main board. It is cheaper than buying a new main board.
The problem is in the main board if this keeps on happening, the board has to be replaced.
Good luck.
Apr 01, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Memorize tel number
I believe there is a clear memory function on this machine.
Otherwise try to reinitialize the main board.
Try : holding menu + * + # , with other hand turn on machine.
The machine should do a cycle, then come to a ready.
This resets the main board. If this function does not work, I need to find the right code process.
Feb 09, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
53 people viewed this question
jasbo
jasbo
