Question about Whirlpool Washing Machines
My whirlpool washing machine front loader has the CONTROL LOCKED light on and i can't get it to do anything i unplugged and plugged it back in but nothing changes?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
I have a whirlpool duet front loader I have had error code 5d appear and the machine has stopped what should I do as the door is locked and I can't remove my clothes
The 5D really stands for SD (SuDs) and is an oversudsing code. The machine shuts off. Try unplugging the unit for about 30 minutes. Then plug it back in and set control to drain. This should release the door.
This alarm may also occur if the drain time takes very long time. Try washing without soap to clean the machine. Use HE soap and use the correct amount. Don't think more is better.
Sep 04, 2016 | Whirlpool Washing Machines
Whirlpool front loader keeps tripping fuse when turned on
Either a dead short or you you are using a ground fault circuit breaker.
gfic Google Search
Sep 28, 2014 | Washing Machines
Control locked light on
Try holding down the end of cycle button for at least 3 seconds.
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control locked light is on, machine is currently inoperable.
Push and hold the end of cycle button for 3 sec to lock or unlock control panel. here is the manual if you need.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606218.pdf
Good luck and please rate FixYa!
Apr 13, 2009 | Washing Machines
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Control Locked
you have to push a button on right side which tells you to hold down this button for control lock
Sep 14, 2007 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
