Question about Home
We have a neptune bar mixer shower that has been fitted to the wall and plumbed. All the water has been turned back on, the hot water is working fine but nothing is coming through the cold water side. cold water is working though all the other taps. what might be the problem? the shower did not come with a manual either!
  • 909 Answers
Possibly switch off hot and cold water then undo cold water flange closest to the outlet and see if water comes out.if it does, tap assembly is faulty. If not, go back to where next available connection to the pipe was made. Work back untill you find the problem.
Posted on Aug 05, 2010
I JUST INSTALLED A TITAN N-120 TANKLESS HOT WATER HEATER AND IT WORKS FINE FOR ALL THE SINKS BUT IT IS NOT PROVIDING HOT WATER TO THE SHOWER AND THE WATER FLOW HAS DIMINISHED IN THE SHOWER AS WELL.
It's doubtful your water heater unit is the problem. There is simply no reason for it to only work on sinks unless some how the pipe size was drastically reduced coming out of the unit so sinks got plenty of hot water but the shower does not. Take a second look at the installation. The pipe should not be less than 1/2" coming out. If that's OK then consider a clog or valve problem.
May 18, 2015 | Titan SCR2 N-120 - 11.8 KW Tankless Water...
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Dec 09, 2013 | Stiebel Eltron CK20E Electric Tankless...
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Dec 09, 2013 | Water Heaters
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Jan 02, 2013 | iflo Home
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 16, 2012 | Water Heaters
Got a gocta w-26mixer shower bar fitted cold tap
from a plumber all hot and cold connections on all major showers are hot on the left and cold on the right just like the taps on your sink or washbowl
Dec 09, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Home Logo
83 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
