I am using EX accounting package. It has a hardware lock attached to the printer port. I am using Windows XP as the operating system and when we try to open EX it says HASP driver is not installed. Please let us know what to do.
The official website for EXNGN 1.5 www.myexonline.com is down and not letting in even registered users.
Posted on Oct 07, 2011
    Sergeant:
  • 191 Answers
All you have to do is go to the website and download HASP driver then install it. That should do the trick.
Posted on Aug 05, 2010
How do I connect my DELL Inspiron 3521 laptop to the HP Photosmart D110 Printer? The laptop is not recognizing the Printer. Whenever we try to download printer software, it says "System Driver cannot...
First of all, what is your Operating System? XP? Windows 7? Windows 8? Are you connecting via Wireless or USB? Is your system 32-bit or 64-bit? If connecting via USB, try different USB ports on the laptop and a different USB cord just to be sure. If you can get into your laptops Device Manager you can go under Action and tell it to scan for hardware changes while the printer is attached to the laptop. Windows 7 & 8 usually have decent Plug and Play features and may pick up the driver.
Are you getting the driver from HP directly? If so, make sure you are matching the Operating system exactly (ex. Windows 8 64-bit/Windows 7 32-bit). You can discover your system type by right clicking on the Computer icon and going to properties. You may also want to try an HP Universal PCL 6 driver if the driver for the actual printer will not download. Save the driver to the desktop or a designated file within the C drive in case your temp folder is corrupt and run it from the local save.
There could be other issues, such as a 3rd party firewall blocking the driver or the Anti-Virus could be an issue as well.
I hope this helps!
Oct 22, 2013 | Dell Computers & Internet
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
I cant use usb printer to get print out from dos base softwear
If you are using a NT based Windows (ex. win nt, win 2000, win xp, etc...) you could try sharing the printer than MAP it as a network printer and direct it to a virtual LPT port with a DOS command ex: net use lpt2: \\ComputerName\SharedPrinterName /yes
Than setup the DOS software to print on LPT2 it should worke, i've done this many many times
Note: if you absolutely have to use LPT1 dont forget to change the physical LPT 1 port in Windows hardware manager to something els so it do not conflict with the virtual one
Feb 15, 2011 | Epson LX-300+ II Matrix Printer
Error 1603
When you try to install a Microsoft Windows Installer package, you may receive the following error message:
Error 1603: A fatal error occurred during installation.
If you click OK in the message box, the installation rolls back.
To resolve this problem, do any one of the following, depending on the cause of the problem:
  1. On the Windows desktop, double-click My Computer. The My Computer window appears.
  2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties.
  3. Click the Security tab.
  4. On the Security tab, do the following:
    • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account.
    • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.
    If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box:
    1. Click Add. The Select Users or Groups dialog box appears.
    2. In the Name field, click SYSTEM, and then click Add.
    3. Click OK.
  5. In the Permissions section, click to select the Full Control check box underAllow, and then click Advanced.
  6. Do the following:
    • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK.
    • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.
    Note If you receive a security message, click Yes.
  7. Wait for the operating system to apply the permissions that you have selected to all child folders.
  8. Run the Windows Installer package.
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
I've plugged in my usb from my printer and set itbut my printer is saying that there is no computer connection
Is the power on both the computer and the printer?
Try other usb ports on the computer, in case one of the usb ports is not functioning correctly from a hardware point of view.
Usually, on hp printers, if you plug it in, it will be recognized by the Windows 7 computer.
What operating system are you using? 7, Vista, XP?
Also, do you have automatic updates enabled for your operating system?
Jul 14, 2010 | HP Officejet 4315v All-In-One InkJet...
Unable tu use wipro ex-1050 printer on window-xp
Click on the link below. When you reach the page, select XP and scroll down to locate your printer. You will see the driver for your printer there. Click on the link to the left of your printer and download the driver. Hope this answers your question. All the best!
Greg
http://www.wepindia.com/Downloads/DownloadDrivers.aspx
May 29, 2009 | Microsoft Computers & Internet
CanoScan640P ex
If upgrading an existing PC to Windows XP from an earlier versionof Windows, Canon recommends a "clean install" to ensure reliableoperation of drivers. If a clean install is not possible, it isessential that drivers for your existing Canon Hardware are UNINSTALLEDprior to upgrading to Windows XP. After the installation of Windows XP,the drivers for your Canon Hardware can then be re-installed. Canon has released a software utility to uninstall USB and SCSI Scanner drivers for this purpose. Click here to download this utility.It is recommended to consult our Driver Downloads page and use the latest driver for your product. Canon supports several scanner models with Windows XP. Windows XPsupport is offered for Windows XP Home Edition, and Windows XPProfessional.The following older models are not compatible with Windows XPdue to hardware design: IX-3010, IX-4015, IX-4025, CS 300S, FB310,FB61
Source
Sep 20, 2008 | Canon CanoScan N640P Flatbed Scanner
Hp printer problems with vista
Hello, you will need to complete the add new hardware wizard, sometimes the drivers are corrupted and the wizard ends before all installation takes place (undertaker02 this is also for you) Do this:-Log on to your computer by using an administrator account.
2. Click Start, and then click Run.
3. In the Open box, type regedit, and then click OK.
4. Locate and click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\LPTENUM
5. Right-click the registry key, and then click Delete.
6. Under Confirm Key Delete, click Yes.
7. Close Registry Editor, and then restart your computer.
When Windows XP restarts, it will detect the printer and install support for it. After the printer is installed, it will no longer be detected each time you start Windows XP.
Apr 28, 2008 | Microsoft Windows Vista Ultimate Edition
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Computers & Internet Logo
Alun Cox
David Payne
David Payne
