Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error E5 Thank you for your reply CowboysFanZ. We have checked and the cartidges are in the correct position. Also, the two cartridges currently in there are the same that were in the printer before we run the cleaning function H. The error message came up after that. Do you have any further suggestion? Many thanks
    Scholar:
  • 99 Answers
According to Cannon, the E5 error is only caused by a cartridge that is either in the wrong location or not seated correctly. So if you have taken out and put back the cartridges and they are seated properly I'm not sure where we could go from there.
I know this is a long shot, but turn off the printer, take out ALL the cartridges and turn the printer back on. Then power it off, install the NEW cartridges and power it back on again and see if that will reset it. Short of that my only suggestion is to contact cannon, but I have and they are the ones telling me the cartridges are in the wrong location. Lets try resetting it and see what happens. //D
Posted on Apr 26, 2008
E5 error how to rectify the error on the printer
I have an MP160 which is now over 7 years old and still going strong. I refill my own cartridges and sometimes get the E5 error after refitting a cartridge. More often than not this fix works for me.
With both cartidges fitted and the printer turned on, open the printer top and wait for the cartridge carrier to move left then right. Immediately it begins to move to the right, quickly push the carrier with your finger as far to the right as it will go and close the top. If you hesitate too long and the carrier starts its travel to the far left, close the top and wait until the whirring noises stop and try again. That usually clears the E5 error.
If it doesn't, open the top, wait for the carrier to park in left position and remove and replace both cartridges. After refitting, give each cartridge a gentle wiggle to help ensure that all the electical contacts are properly seated in the carrier, then close the top.
Note that if the cartridge is faulty, in my experience the E5 cannot be eliminated.
Oct 15, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Error code e5
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
Jul 27, 2014 | Electrolux Refrigerators
My canon MP 145 printer displayed E5. How can I solve my problem?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 20, 2011 | Computers & Internet
My printer canon ip 198 shows error e5..what should i do?
Hi there
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E29 - EEPROM error
E42 - Scanner error
Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E5 error
hi try to install a new driver from here http://support-my.canon-asia.com/EN/search?canonsearch=1&lang=EN&category=Multifunctional+Printers&series=PIXMA&model=PIXMA+MP160&menu=Download otherwise ur error code means The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly. Install cartridges properly. so try to clean the cartridge pinout well by using Acetone or something like that also try to clean the pinout of the cartidge mount inside the printer when it's power is off.
Jun 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to reset the Canon MX850 Printer, after ink change and counter reset? After I had changed ink cartidge and reset ink counter, I was able to print without problem. But this was only for a few days. ...
One way is to hold the 'Stop/Reset' button for at least 5 seconds until the display shows a new message about ignoring the current ink condition. This does not reset the chip but it does allow you to continue printing with the refilled ink tanks.
Mar 04, 2009 | Canon PIXMA MX850 Multifunction Printer
E5 and 2,114,0 errors on Canon MP160
Empty cartridges may cause this error. Here is the error code list for your printer
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error E5
when the error E5 is ocured it means the COLOR cartridge is either the WRONG cartridge, or you have a balck cartridge in the color cartridges spot. Please verify you have the correct cartridges in the correct locations, and that you may not have installed the black in the colors location. Please let me know if this fixes your problem. Thanks //D
Apr 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error E 5 on the Canon MP160
Try this website:
http://www.techsupportforum.com/hardware-support/printer-support/174311-solved-error-cannon-mp160-after-refilling-ink-tank.html
Dec 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
154 people viewed this question
old marine
old marine
