Question about Garmin Nuvi 660 GPS Receiver
Hello pretty please, if you could help rescue one problem. I have a navigation nuvi 660 Yesterday I got through the web updater updates loaded. Then I start navigation, and now I can not find more satellites. I noticed that during boot the screen displays the ongoing GPS modernization, below is a line that is not filled and remains at 0% and goes. I also noticed that if I connect the device again with the web updater, we always offer updated GPS Chipset Type G. Still ticking this update to download, own transfer (initialization) in the normal way to 100%, we then show that the update was successful and to click Finish to exit. Please if you could help me to solve this problem and can fix the heart of the peaceful journey of the leave. Greetings Thomas Merc
  • Garmin Master
  • 2,130 Answers
This is referred to as the "Zombie Mode". It happens because the main board in the GPS can not communicate with the flip GPS receiver board to poll for its firmware version, so its trying to reflash it but it can't.
You can read more abut this problem here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Aug 05, 2010
My nuvi 660 turns on but displays "loading maps"
The problem is that the nuvi 660 gps receiver is jammed and needs to be reformatted.
What you have to do is to disconnect the gps, and connect it to a computer, then format it.
After formatting it, you download the self extracting archive files for your nuvi on to your hard drive, then connect your nuvi to a free USB port on your PC interface cable and allow your nuvi to initialize and enter USB mode, Unzip the files by running the downloaded executable files, then follow the instruction provided by the launched update application on your PC.
Then install it back in your car and turn it on, it will work once again.
Take care and good luck
i hope this helps?
Dec 05, 2010 | Garmin Nuvi 660 GPS Receiver
Hi, deleted some important functions from my nuvi 660. How can i get the software back again. Same software which is in the navigator when u buy it from any place. Pls urgent help needed
find the software needed on the below link:
http://www8.garmin.com/support/download_details.jsp?id=1921
If the above is not what you want, then you can perform a update. I assure you that updating will help ot reinstall the deleted software.
Follow instructions on how to update your nuvi 660 from the tips posted by me on the below link: http://www.fixya.com/support/r6547054-update_garmin_nuvi_gps
I hope this helps.
Good luck.
Nov 29, 2010 | Garmin Nuvi 660 GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
Dont Aquire Satellites
Ditto.. even after updating FW...
Jun 14, 2008 | Garmin Nuvi 660 GPS Receiver
NUVI 610
Voice prompts (e.g. "Turn right in 500 ft."): yes (internal speaker) Speaks street names (e.g. "Turn right ON ELM STREET in 500 ft.") : no
Well sir, sorry this unit is working fine and you must do an update.
Garmin is the best product on this market. I use it since 12 years now. Aircrfat, marine and automotive.
Please use Web updater from Garmin and download the latest update who correct your little problem.
Look ---->
Change History Changes made from version 4.10 to 4.20:
  • Improved the map drawing speed.
  • Corrected issue with proximity points in areas with many roads causing the map to draw slower.
  • Corrected issue where all traffic delays were represented as 1 minute
---> http://www.garmin.com/software/nuvi610_420.exe
Sep 05, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
111 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
