Question about Ovens
WHEN SETTING MY BF641 ON GRILLING & THE TEMPERATURE ON MEDIUM I GET 4 FLASH LINE, WHICH MEANS I HAVE NOT SELECTED THE CORRECT TEMPERATURE. KIND REGARDS, ROBIN JOHNSON.
  • 909 Answers
If you are farmiliar with your oven and are now experiencing the problem you described, then i would say the board is faulty I have had to replace 4 these past few weeks.(different ovens though.)
Posted on Aug 05, 2010
How do I operate the oven
On the left there you'll find a know that switches between oven, oven & fan, grill & main grill. Select Oven, normally the first one & then on the temperature knob (separate know) select the temperature you want.
Feb 09, 2017 | Ovens
I turn on the top oven and the grill element also comes on. I can grill ok but I cannot use the top oven for baking. Any advice please?
Hello;
My name is Peter. i am a retired field service appliance technician.
It sounds like you have a bad control. I can not be sure of this because you did not proved a model number so I can see what you have
Sometime these components are inexpensive and easily replaced.
You model number is on a metal plate on the upper face of your oven after you open the oven door.
May 12, 2015 | Ovens
We just moved into new flat with a whirlpool oven Model No: 6AKP524/1X. There's no manual. What are the 4 buttons on top/front for.
Unfortunately we are unable to offer assistance to those residing outside of the United States. Please visit http://www.whirlpool.com.au for assistance in your region.
Jun 09, 2017 | Whirlpool Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
My AEG oven does not heat up, nor does the grill work. The oven light and fan comes on when selected but the light located with the temperature control dial does not illuminate. This light normally...
DearDavidgale730,
I am supposing this oven/grille is electric, and is plugged in to a power source.
From your description, I'd say you have a serious problem and should no longer consider turning on the oven or the grille.
Having made that decision, take an electric meter and test the socket or wires that connect the stove/oven to the wall.
See if the current is flowing in both legs of the plug.
(Remember, two are "Hot", one or two are grounded.)
If not, correct the problem with the fuses or circuit breakers that are feeling the appliance.
If so, open the appliance up and test all circuits with that electric meter to determine the problem.
Often the problem may be a bad socket for the oven heater element, a bad element itself, or a burnt wire going to the element socket.
God bless your efforts.
Jul 04, 2017 | AEG B8139-4-M Electric Single Oven
I have just moved into a flat with a stove electric oven and I can't work out what the dial symbols mean. How do I use the grill and oven etc
check your manual if you don't have one check the internet for your model and download and then print it out.
Oct 22, 2009 | Stoves 720EF Electric Double Oven
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Ovens Logo
102 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
