Question about Microwave Ovens
I was moving from one house to another and later when i pluged my fridge it was lighting but not geting cold, two days later the light inside went off and still not getting cold.
  • 909 Answers
If the compressor is hot then you have a compressor fault. If the compressor is cold, then the thermostst is faulty. Im taking it the fridge is a mechanical control.
Posted on Aug 05, 2010
My fridge suddenly stopped cooling, if i restart it, the freezer start getting cold, may even make ice, but it all quit after few days ar few hours. Any clue?
If the capillary tubes are visible on the back, take a hammer and lightly tap on them about every half inch all the way around to break up the grunge.
Jun 16, 2015 | Danby DMW7700BLDB .7 cu. ft., 700 watts...
Surface light bulb missing on SCA1000HCC01
Check inside the microwave for a cover or in back of the unit for a cover which the light would go inside
Apr 20, 2015 | Microwave Ovens
If water blew up in microwave will it damage the microwave
if the display and the lights are out after the water/steam explosion then yes id say it did have an adverse effect to the operation of the machine , there are no user servicable parts inside a microwave so dont open the case your self , these little boxes contain enough power to light a house up ,even with it unplugged from mains power
Jan 10, 2015 | Rival MT660 Microwave Oven
Ge spacemaker xl jvm1340
If you had too high a wattage the excess heat may have melted the wires or ruined the switch.
Nov 28, 2013 | Microwave Ovens
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
How do i remove the halogen light in my micowave
I have a similar Kitchen Aid model. The little light inside my unit also went out. I called Kitchen Aid and they scheduled a tech to come out to change it. He said the only way to get to it is to pull the unit out from the wall (it's a built in unit). $150.00 bucks later I had a light for about another year before it burned out too. Needless to say, the heck with it, I don't need the light that bad.
Nov 16, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
I have a whirlpool fridge freezer (model 20rud4). It was working fine until about 3 weeks ago and tthen suddenly the fridg is not staying cold eneough. It was originally set to 5 degrees centigrade . i...
it is possible that your fridge has developed a snag in its cooling system. what could be done from your end will be to first of all switch off the fridge for at least 8 hours. allow it to totally defrost. then switch on to see if the cooling returns. if so reduce the thermostat to 7 degrees and check. if the cooling returns then you will need to check for frosting inside due to failure of the thermostat or the auto defroster. if there is still no cooling then your gas has leaked, failureof the compressor, failue of the valves in the compressor could be suspected. Probe with these inputs. Good day
Jun 30, 2010 | Microwave Ovens
The only part working is the light inside.
If the fuse was blown, the light would not come on. The fault could be one of numerous. It is recommended that the appliance is repaired by an expert in this field. As microwave ovens run on very high voltage it is extremly dangerous for a novice.
Sep 11, 2009 | Microwave Ovens
Electric went out to the house, it came back on, and the microwave inside light works, the display panel reads just a " : ", and none of the buttons work. I have tried resetting the breaker with same
Hi cschnur,
     It seems that you might need to replace circuit board.
All the above mentioned conditions refers to a faulty circuit board. You might have blown few Ic's.
Take a voltmeter, check the continuity. If you are aware of the Ic's, replace them.
Unless, look for a tech, a used board ( On http;//www.ebay.com ) or purchase a new one.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
