I have a Miio MPH400 wall/floor mounted heater,2200watts. It is on a timer but I cannot decipher how to set or use the timer properly. I would be happy to not even use the timer, just to be able to turn on the heat when I want to. The heater works well, otherwise.
  • 4 Answers
SOURCE: heater will not stay lit
yes for sure it's the thermocouple
Posted on Feb 05, 2009
  • 19 Answers
SOURCE: How can I locate the blend door for the heater/defroster
you have a bad control switch.
Posted on Mar 05, 2009
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • 3197 Answers
SOURCE: My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Posted on Aug 03, 2009
hvac1960
  • 2133 Answers
SOURCE: Hitachi Model A/C unit, RPK10FSNM,
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Posted on Jan 02, 2011
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
This electric baseboard heater will be wallr mounted. Must it be raised and mounted above the floor or can it be set on the floor? Thanks, Mel
Mel, if you wave wall to wall carpeting, it should be about 1 1/2" off the carpeting. If you have hardwood floors 1/2" will suffice.
Hope this helped you.
Apr 05, 2011 | Heating & Cooling
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
The ticking of the timer is so loud and can be heard on the other side of the wall inside the house. Is there any way to quiet the timer or do I need to just disconnect the whole thing to get rid of the...
Try mounting on rubber standoffs. The mechanical timers are noisy and when mounted on a wall that amplifies the noisy.
As a test, un bolt it from the wall and see if noise is acceptable. If so, find a cushioned mount.
Sep 22, 2009 | Intermatic WH40 - Water Heater Time Switch...
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Electric wall mounted heater
Make sure that the heater is mounted where convection currents occur freely. When heat builds up around the top of the heater its temperature will rise uncontrollably. You'll be luck not to get a fire.
Jan 18, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Heating & Cooling Logo
353 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
