Question about Dishwashers
High pitch continuous sound during washing cycle. not during fill or drain
  • 135 Answers
Probably have something stuck in the chopper blade. You can try to dismantle the pump and clean out the obstruction, from the inside. But sometimes it will eventually work itself out. So try and run few more cycles.
Posted on Apr 26, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Kenmore dishwasher has loud noise during fill. If you let it go, the washer fills. Once filled, noise stops and wash cycle continues. Sounds like plumbing does when there is air in the pipes. Not a...
This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
Apr 19, 2009 | Kenmore Dishwashers
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
