Question about Cannon Office Equipment & Supplies
I have a Cannon MP640 which is connected via WIFI to an Apple mac, it has been working properly but now keeps going to the pause mode and will not respond. I have called Apple and they suggested that you may be able to help.
I have the exact same problem. it has been working fine up until now.
Posted on Aug 09, 2010
Can I use ethernet and wifi together?
No, you can use both type of connection without problem. Ethernet is a direct wired and generally faster connection. Wi-Fi is a via air form of transmission and is highly dependent on how many cellphones and computers are connected at any one time. In airports where I work, this is a big problem. My airport lounge has its own Wi-Fi provided by DataValet for this reason.
When you connect via Ethernet the connection will be used automatically. when you wish to use Wi-Fi, you will choose that in settings. You should only use one, although it isn't going to hurt if your try connecting via both. My guess, is that it will take the best signal.
Nov 11, 2015 | Apple iMac Computers & Internet
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
How can I watch Netflix on this tv, either through direct streaming or via Mac laptop connect? Westinghouse VR-4030 flatscreen
Go to Best Buy and get an Apple TV for $69. (It's not aTV set. Just a little box that connects to your wifi and streams content to your T v. You hook up the Apple box, change the tv to the hdmi port you plugged it into and get your wifi connected to it. Then select Netflix and log into your account. Or wait for the new Apple to be available for $200. You can also get an Amazon Firestick from Amazon but you will like the $69 Apple TV better.
Sep 15, 2015 | Westinghouse Televison & Video
I can't get my printer to print. It seems to be stuck on Paused.
If your printer is connected via wireless network, please try the following.
1. Check if WiFi light indicator if enable and has signal strength.
2. Check if your computer is connected to your wireles router.
3. Reinstall the printer driver.
If your printer is connected via USB cable, please try the following.
1. Check if the printer and computer is properly connected.
2. (for Windows), Check Device Manager if USB Printing Support is present, (for MAC) Check Apple System Profiler if EPSON MFP 2.0 High Speed is present under USB device tree.
Nov 03, 2011 | Epson Artisan 800 All-In-One InkJet...
Can't print
I had the same WiFi problem, reconnected by USB and failed again. However, cleaned up printer settings on the iMac and reinstalled. Now it works but I am dissapointed about the WiFi.
Amazingly hard to find info on the Canon Support Site...
Jul 22, 2010 | Canon Office Equipment & Supplies
Canon MP640 not responding to my mac
Did you install the software from the CD or did you download the driver? Are you using Snow Leopard?
If you have Snow Leopard and used the CD, you don't have the most recent drivers. Here is the link to the MP640 drivers. Remove the drivers currently on your imac and download and install from here, including the scanner driver and the MP Navigator (listed under Software).
Mar 12, 2010 | Canon Office Equipment & Supplies
Canon MP 640 not recognized by MP Navigator EX 3.0
Your anti virus software is blocking the Canon software. Restore AV default settings.
Jan 31, 2010 | Canon Office Equipment & Supplies
113 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
