Question about Denon AVR-1907 Receiver
Hi. I've got a Denon AVR-1907 but can't get any sound when using optical toslink-cables. I have both my TV and Blu-Ray connected to the reciever. Can anyone please help me? Tried - Checked the toslink cables - Tried with other toslink cables - Checked if the setup was correct - Tried a Master Reset of the product.
    Brigadier General:
  • 8,546 Answers
Have you considered your source may be the problem if the receiver isn't?
You say setup is correct. If so it would work, no?
Posted on Aug 05, 2010
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
I have a denon 1907 reciever, which has no hdmi hookup. I bought a blueray with hdmi. My tv has hdmi. can i some how use hdmi for the tv and cables for the receiver
you should have an optical audio out on your tv and optical in on your reciever
adjust the settings on the tv appropriatley and you should be good to go.
GOOD LUCK AND PLS RATE THIS POST!!!!
May 03, 2010 | Denon AVR-1907 Receiver
I have a Denon AVR2801/981 and cannot get to the on screen set up using the remote. I need to assign the optical audio input for my blu ray player. Is it a problem with the remote or is it with my...
On-screen display (OSD) isn't coming up because you're only viewing picture from your Blu-Ray player. You need to switch TV input over to your receiver to get the OSD. But you probably figured that out by now. Don't worry, I've done that before too.
Dec 06, 2009 | Denon AVR-981 Receiver
My Denon AVR-5800's optical (toslink) inputs no longer work. My Tivo, DVD player, HD DVD player, etc. does not produce sound so I know it's not the toslink cables. I've configured the assignments...
Press the input mode on the front of the unit to select auto while on the input you want to use if this is does not work you will need repair on the unit
Jul 04, 2009 | Denon Audio Players & Recorders
Hi with my denon avr 1908 can i run video through HDMI cable and sound trough Coaxial cable so i can get 5.1 surround from my sky HD box
you can get 5.1 using HDMI connection.
other wise in the set up you can configure the denon to not use the hdmi audio and configure that input to use coaxial or optical all digital inputs allow for 5.1 once all connections are made on the front of the unit find the input mode button and select auto
Jun 30, 2009 | Denon AVR-1907 Receiver
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Connecting Sony BDP S550 Blu-ray player to my Denon 3802 receiver.
The only thing you need is an optical audio cable (toslink) connecting the Blu-ray blayer with one of the three inputs on the AVR3802. Then assign this input in the system menu to the input you like (e. g. DVD) and that should be it. The Receiver automatically detects the sound format from the Blu-ray and changes from stereo to DTS, DD5.1, 7.1 or whatever.
Regards
Thomas
Nov 01, 2008 | Denon AVR-3802 Receiver
Connecting a sony blu ray 350 to denon 1601/ home theatre
Yes select audio optical out on your Blu Ray Player under Audio settings and make sure the Denon is set to Optical or Auto in. You should be set to go
Sep 27, 2008 | Denon AVR-1601 Receiver
Denon AVR-1907 Receiver Logo
319 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
