Question about Ovens
While cooking in the oven evey now and then there is a loud noise, like a car backfire?
  • 909 Answers
Sounds like you have a short. That bang is the power discharging either to earth or even a power protection capacitor discharging. Need to call a technician with equiptment to check for problem area. Strange that the circuit breaker did not activate.
Posted on Aug 05, 2010
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
Kitchenaid superba oven
What is the model number?
Jun 19, 2013 | Ovens
Turbochef loud noise
You have blower motor bearing problem. If it only make noise during cooking Thanks Please rate me
Nov 14, 2011 | TurboChef TORNADO Electric Oven
I have a 2 yo fridgedare stove that the oven went out..the stove top is working but now oven isn't? The other day while i was cooking a loud noise like a "boom" happened and now oven not working?...
The noise you heard was probably the oven element short circuiting to earth. If the cooktop and grill are working then the fuses, internal/main must not have blown. If this is the case the oven indicator light should come on when you turn the oven on. If it does the oven element is definitely faulty and needs replacing.
Mar 05, 2011 | Frigidaire Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Loud noise from Baumatic B905 oven whilst cooking and after.
not that familiar with the brand but in other case have fourn the board to be engaging the self clean. not a good sign. and for this model i would think very costly. wishful thinking says the oven temp sensor but i think you have a fauly board. get the same thing with alot of frigidaire ranges.
Aug 01, 2010 | Baumatic B905SS Stainless Steel Electric...
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
151 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
