Question about HP LaserJet 4700 Printer
How do i remove an error 59.30 for hp4700 printer
  • 903 Answers
The first thing to check is that the transfer unit is installed the right way. Did you recently replace it? Try taking it out and putting it back in, then turn the machine off and back on.
Hopefully it will work now, but if the error comes back you may have a bad motor.
Posted on Aug 11, 2010
3 Suggested Answers
  • 10 Answers
SOURCE: LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
i have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
Posted on Oct 19, 2010
SOURCE: error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Posted on Jun 14, 2009
Hp4700 Yellow registration is off even after changing cartridge and full calibration run several times.
In the system setup options, look for the Registration Menu. This may allow you to train the registration yourself, back into exceptable levels. Otherwise, call for or bring in too, a HP service center.
Aug 26, 2011 | HP LaserJet 4700 Printer
49.c02 Error To continue turn off then on HP4700 LaserJet Color Printer
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt
data during transmission to the printer.
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79
Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
displays only with a certain software
program or print job, contact the
software vendor for assistance.
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
printer that connect it to the network or
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
each DIMM and EIO device one at a
time, making sure to turn the printer
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
determine that it causes the error.
Aug 08, 2011 | HP LaserJet 4700 Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
How do you reset the fuser count on a hp4700
The fusers for this particular printer have the reset technology embedded in them. There is no menu option to reset the maintenance count. If upon installing the new fuser it hasn't reset the count itself, you need to contact your supplier about getting a replacement.
Aug 20, 2010 | HP Office Equipment & Supplies
My HP4700 Printer is displaying a 49.5001 Error message
Control Panel Message:
49.XX.XX
PRINTER ERROR
To continue
turn off then on
Description:
is at fault, which is usually indicated by a 79 Service Error.
Recommended Action:
the printer memory.
computer.
printer.
device.
12. Remember to reconnect all of the
cables that connect the printer to the
network or computer.
13. If the error persists, upgrade the
firmware compact flash card. See
Installing a flash memory card
on page 113.
14. Replace the formatter and calibrate
the printer. See Full Calibrate Now
on page 521.
Dec 16, 2009 | HP LaserJet 4700 Printer
Hi i have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges
Is this and old cartridge?
Trying changing it. Use a new one.
Good Luck.
ps when I know that I'm running out of tone, that is usually what I do to get a few more pages to print,
until the new cartridge comes in. LOLl
Nov 05, 2009 | HP LaserJet 4700 Printer
Hp 4700 "clunking"
It may be one of the toner cartridges or fuser.
Oct 23, 2009 | Office Equipment & Supplies
Hp4700 Color laserjet makes groaning noise
Could be dry fuser bearings or a noisy transfer belt.
Jan 06, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4700 Printer Logo
477 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
