Question about RIM BlackBerry Curve 8520 Smartphone
Hi , i bought a curve 8520 3 weeks ago and it has been brill ,however last night the screen went white wiv the hourglass..i hav took the battery out for several hrs..and then replaced it...and my phone just turned on itself with the white screen again and the hourglass ?
    Scholar:
  • 55 Answers
The BlackBerry has the feature on auto-start. When you insert the Battery, the device will automatically boot-up. It'll be showing an hour glass while loading the settings. But if it is longing for more than 10 minutes, there might be some error in the OS. It's better to contact a near-by authorised Service Center.
Regards
Vineeth K.
Posted on Aug 05, 2010
I have the blackberry 8520 and last night it lock and i got a message saying memory cleaning. Now for the last 12 hour all i have is a white screen with a timer, the phone is completely...
Try entering any password in your blackberry until you reach 10 times password failure, it should be make your blackberry curve 8520 unlocked also erased all your previous data. After your blackberry unlocked, setup new password for your phone. If this solution not working the only option is reflash your blackberry phone. Good luck!
Mar 09, 2011 | RIM BlackBerry Curve 8520 Smartphone
It has a white screen and saying app523
Follow the below steps to get rid of this error message: 1. Take the battery out and put it back in after 30 seconds or so
2. While the device is rebooting (or while the hourglass is still spinning), plug it into the PC
3. Then open the application loader and remove the 3rd-party application that's causing the issue
4. Worst-case is when you need to wipe the device using JL_Cmder.
Mar 08, 2011 | RIM BlackBerry Curve 8520 Smartphone
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
Blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Jun 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Hello, my blackberry curve 8520 has a horizontal
I have the same problem, but it's a vertical white line.  I have a BB Curve 8310.  From what I've researched on the web, it seems the LCD screen wud have to be replaced.
Feb 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Curve with white screen with hourglass and red light on
If the flipping hourglass stays for longer than 2 min our Blackberry may just need a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Aug 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8520 Smartphone Logo
306 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
