Question about Refrigerators
My phone operates only in loudspeaker - Refrigerators
  • Refrigerators Master
  • 1,606 Answers
Orchestrate virtual networks by engageing scalable niches and repurpose bleeding-edge channels
Posted on Aug 05, 2010
How do I connects my lg phone to the loudspeaker
If you mean to the internal speaker, there should be a speaker symbol when making or receiving a call, which you press to activate.
If external loudspeaker, you can patch your earphone out socket to the line-in of your hi-fi / amplifier.
Do not connect an external loudspeaker directly to the phone - this will damage the phone.
If your amp /speaker / soundbar has bluetooth / Wi-Fi capable of pairing with your phone, then switch on both devices and pair them.
May 10, 2018 | LG Cell Phones
The loud speaker on my g1 doesn't work how do I replace
  1. 1st OF ALL, YOU WILL HAVE TO UNSCREW THE PHONE
  2. THEN YOU WILL REMOVE THE BAD LOUDSPEAKER
  3. THEN YOU WILL HAVE TO GET A NEW LOUDSPEAKER @ ANY PHONE REPAIR SHOP
  4. THEN FIX THE NEW LOUDSPEAKER IN THE PHONE
  5. TEST IT
Jan 10, 2011 | HTC G1
I updated my nokia e71 software. it was noticed that the loudspeaker symbol which used to come immediately after i dial a call is not coming now. Loudspeaker symbol only comes when the call is connected.
2 solutions to your problem.
1. Either restore the phone's software to the original state through Nokia PC Suite.
OR
2. Update the Nokia E71 software with the latest patch from Nokia Service Center.
I have Nokia E71 Black Handset with me and whenever I dial-in and gets success then only I get the "Loudspeaker" option enabled in the right hand corner of the screen. Once you activate this option, the Loudspeaker option is visible.
Thanks,
Amar Narkhede
Oct 06, 2010 | Nokia E71 Smartphone
Cant hear caller expect by switching to loudspeaker
ya you could try just by pressing the $ button ....to start the loudspeaker ,.....
regarding the pin broke , u shd replace it .. clean it with ...soft ( dry ) cloth ..
Jul 06, 2009 | Nokia N80 Cellular Phone
In my mobile there is no loudspeaker option in Nokia 6681
For volume and loudspeaker control increasing or decreasing the volume level when you have an active call or are listening to a sound, press left or right scroll, respectively. Sound applications use the loudspeaker by default.
To use the loudspeaker during a call, start a call, and press the button with the talking face icon and press again to return to earpiece.
If it does not work the speaker, or amp circuit is bad or there is a glitch in the firmware. Replacing the speaker is the only economically viable repair. If the amp circuit or firmware has malfunctioned a new phone is in order.
Jul 05, 2009 | Nokia 6681 Cellular Phone
Not able to here anything, can only here when the loudspeaker on.
there are 2 things that can be broken either the flex cable or the headphone. better try to change the headphone first cuz its easyer and cheaper to change. since u can hear on the loudspeaker it means that the audio driver and the soft of the phone are ok.
Mar 30, 2009 | Nokia 3600 slide Cellular Phone
I want to increase volume of caller.
To actually answer a call using loudspeaker, press the top-left button (options) and then the middle select button (with the option "Loudspeaker" highlighted). You can do this even when Keyguard is activated. (I just checked.) It means pressing two keys but at least it actually answers using the loudspeaker.
To make a call, the only way I can see is to dial first and then press the Loudspeaker button while the phone at the other end is ringing.
Mar 04, 2009 | Nokia 6230i Cellular Phone
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Loudspeaker does not work
What type of phone do you have? and does it have a wide audio headphone connectors ? as same as Nokia phones?
Usually it's a problem with the "headphone" settings...
Good Luck
Nov 02, 2007 | Cell Phones
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
