Question about Adobe Photoshop Elements 4.0 plus Premiere Elements 2.0 Full Version for PC
I have Photoshop Elements 4.0. At the moment I am running it on Windows XP but I am getting a new computer with Windows 7. Will it be compatable with Windows 7. Would I be able to upgrade from Photoshop Element 4.0
    Sergeant:
  • 191 Answers
Yes it might work.But i hope you know that there are upgrade of the Adobe Photoshop Elements 4.0 plus. Please check the adobe website and see the upgrade and compatibility.
Posted on Aug 05, 2010
Is adobe photoshop elements 3 compatible with windows 7
I want to mention that Photoshop Elements 3 is not tested with the Windows 7.
If you have a windows 7 64 bit operating System then it may not even install in it. If you have a 32 bit Operating System then you can try to install it. However it may still not work even on a Windows 7 32 bit Operation System as it was not made and tested for this Operating System.
There is a probability that if you install the Windows XP mode on you Windows 7 operating system then it may work.
Check more about installing Windows XP mode here:
http://windows.microsoft.com/en-IN/windows7/install-and-use-windows-xp-mode-in-windows-7 Install and use Windows XP Mode in Windows 7
Regards
Anand
Aug 30, 2014 | Computers & Internet
I have a belkin f5d8636a.4 wireless router and need to connect it to a new computer running windows 7 using a belkin f5d8053uk usb stick. i need to know are both these items windows 7 compatable or do i...
The Router supports a variety of networking environments including Mac OS® 8.x, 9.x, X v10.x, Linux®, Windows® 98, Me, NT®, 2000, XP, and Vista®
usb stick OS Compatibility: Windows® 2000, Windows® XP 32 bit, Windows Vista® 32 bit
Nov 28, 2017 | Computers & Internet
Adobe Photoshop Elements 3.0 Error problem out of memory
Without your computer specs, it is hard to judge if this is a bug in Photoshop Elements 3.0 or your system causing the issue.
If you are using Windows 7/Vista, please press Shift+Control+Esc to enter your task manager while running Photoshop Elements 3.0. Click Performance. Under Physical Memory, view the "Available." If this number is low, saw under 1,000, your system most likely needs more RAM. In Windows XP, press Control+Alt+Del ONCE to access your Task Manager.
Feb 26, 2011 | Adobe Photoshop Elements 3.0 for PC
I have got Adobe Photoshop Elements 4 which worked fine with my old computer on Windows XP, but now I have loaded it on the new computer it keeps coming up and saying there is a compatability error. I can...
You can try this "Make older programs run in this version of Windows" using the "Program Compatibility troubleshooter" in Win 7 -> LINK
If it does not work, then you need a newer version 8.
Hope it helps.
Oct 31, 2010 | Adobe Premiere Elements 4
WINDOWS 7 - PHOTOSHOP ELEMENTS 2 COMPATABILITY
You are using old version of Photoshop elements. This is a reason Windows 7 having compatibility issue. To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Select Windows XP service pack 2 and click on Ok button. Now access the layers palette in Photoshop Element
Thanks
$ri
Jun 19, 2010 | Adobe Photoshop 7.0 for PC
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
How can I get photoshop elements 6 to work on my computer now that I have windows 7
The system requirements for Photoshop Element 6 shows to be compatible with Windows XP and Windows Vista.
You may want to check with Adobe to see what os Photoshop Elements 6 supports., or to see if there is a patch or update.
You might also try out the XP mode in Windows 7 to see if you can get it installed and working.
Mar 28, 2010 | Adobe Photoshop Elements 6: Windows
Since upgrading to Vista and now windows 7 I cant
Start the "Program Compatibility Wizard".
Tell Vista that you want to install an 'XP' application.
Point the Wizard to the CD-ROM containing the software, and it will install.
Jan 15, 2010 | Adobe Photoshop Elements 2.0
Won't work with Vista 64 bit
Hello
I am running Windows Vista 64 bit also and finding out that there are a lot of programs that won't run on a 64 bit machine due to the fact they are not supported for 64 bit, listed below is info to your problem,
Photoshop Elements compatibility with Windows Vista This TechNote lists which versions of Adobe Photoshop Elements are compatible with Microsoft Windows Vista.
Photoshop Elements Version Compatible with Windows Vista (32-bit)? 6.0 Yes 5.0 Yes
Note: You must download the Photoshop Elements 5.0.2 update to ensure compatibility with Windows Vista.
4.0 No 3.0 No 2.0 No 1.0 No
Note: For the versions of Photoshop Elements that are compatible with Windows Vista, the 64-bit editions of Vista are not supported. Adobe Technical Support can assist you with the features of Photoshop Elements and with issues that also occur in supported operating systems. Technical Support cannot, however, assist you with issues that occur only on the 64-bit editions of Windows Vista. Instead, you can use the following support options on the Adobe website:
  • The User to User Forums, on which you can enter your problem or concern to see if another Adobe user can offer advice. Access this resource at www.adobeforums.com.
  • The Support Knowledgebase, which contains solutions for issues that occur on supported operating systems. Access this resource at www.adobe.com/support/photoshopelements.
dmg49
Apr 15, 2009 | Adobe Premiere® Elements 3.0 Full Version...
Photoshop does not work on vista
When Adobe began shipping Photoshop® Elements 5.0 and Adobe Premiere® Elements 3.0 software in September, final versions of Microsoft® Windows® Vista were not available to complete the testing required to ensure compatibility.
Shortly after Windows Vista becomes available to consumers, Adobe plans to release updates for Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 to provide compatibility with Windows Vista.
Updates for existing Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 owners will be available as a free download from adobe.com, and updated Vista-compatible versions of Photoshop Elements 5.0 and Premiere Elements 3.0 will become available in the same timeframe.
tnx 4 using fixya!!!
Nov 02, 2008 | Computers & Internet
Adobe Photoshop Elements 4.0 plus Premiere Elements 2.0 Full Version for PC Logo
98 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
