Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
My harddrive (WD 1TB essential) does not become recognized at all when I put it into my laptop which is running windows 7. I have checked the cables and the power supply and they are good. I tried to put it into my old computer as well (Win XP pro) and the same problem happens. It does not recognize it.. Any solutions?
  • kasperhaysen Aug 05, 2010
    In fact. It does not show any messages at all. It seems like it is not plugged at all.
    Sergeant:
  • 191 Answers
Yes please try changing the cable and see if it will work and if it doesnt then there is a fault with your hard drive.
Posted on Aug 05, 2010
  • 3 more comments
    what can I do if there is nothing wrong with the cables? - the hdd worked nicely for less than 12 hours ago and I have not damaged it in that time.
  • untraceme
    untraceme Aug 05, 2010
    that mean when you last removing the cable from the computer you did not use the safely remove drive hence you hdd has been damage. But most of all did you try another cable ? If yes then i suggest you take it to the tech department for them to service it for you.
    I did use the safety remove application. I guess it will go to the tech department. Thx for your pieces of advice. :)
  • untraceme
    glad to be of assistance to you
  • untraceme
I'm having the same problem for the second time this year. I was very careful to "safely remove drive" etc. WD says to re-format! I asked about all my data and they said it's gone! I used a free damaged partition utility successfully the first time. This time - no luck. I'm more than a bit angry at WD and that they sell this as a back-up storage system. Don't rely on this drive for anything!
Posted on Aug 20, 2010
WD Software will not load up, and Windows keeps giving me an I/O error. With the I/O error, I am not able to see or access any files that I have on my WD MyPassport 1TB, SN WXD0AA9W6561
Have you tried another USB port.Try not using a USB hub and plug it into a different port on your PC. Also try temporarily disabling your virus and anti-spyware program. My virus program Antivir always blocks my WD software. There may have been an update that now blocks it. Check all your cables and plugs on the WD drive and if still not working try starting your pc in safe mode and see if the WD drive is recognized. Hope this was some help, Thanks for using FixYa
May 11, 2011 | Western Digital My Passport Essential SE...
I have a WD 1TB My Book Essential for Mac. It was working wonderfully until last night, my husband opened the drive on our iMac and was able to access the files on the drive; however, when he attempted to...
Did he try to recycle the files using the iMac? because sometimes if you recycle the files it will show that it was deleted from the harddrive but in reality they will remain there but the are hidden. I think the best way to check if the drive is full is to plug this drive to a computer that has a Windows operating system and make sure to show hidden files and delete all hidden folders that you will see in the drive to free the space completely.
Hope you find this helpful!
May 05, 2011 | Western Digital WD My Book Essential 1TB,...
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
My drive is not being recognised and im not sure why up in till this point it has worked fine? It is a WD Essential Model - Wdbaaf0010hbk - 1TB drive it has alot of valuble information that i would hate to...
when your external drive does not appear in "my computer" or not recognized in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer
Oct 03, 2010 | Western Digital My Book Essential 1TB...
Windows 7 is not recognizing and comes up as a cd drive?
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
External Harddrive locks up Windows Vista Home Basic on start up
I would suggest two things.
First, plug in the 1TB drive when it won't cause problems, and go to Disk Management under Administrative Tools (for example right-click the My Computer icon and select Manage, then drill down to Disk Management). Check your 1TB disk's drive letter there, and perhaps change it to some letter further down the alphabet, like "T" for example.
Then run a full check on the drive - right-click the 1TB drive and select Properties, go to Tools tab and run "check for errors", selecting the option to repair system errors.
After that's finished, plug in the 500GB drive and run a full check on it as well, just to make sure.
Now try booting up with both disks plugged in - the problem should be gone.
If it's not, then it may mean, that your BIOS is trying to open this 1TB drive to make an option to boot from it possible, and it has troubles because of it's size; some older BIOSes can't cope with disks of that size. Should this be the case, you can go into BIOS Setup and disable booting from other devices that the primary internal hard disk.
A
Jan 02, 2010 | Western Digital My Book Essential Edition...
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
787 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
