Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Error code c7 12 with red light on circuit board. The unit has worked great for 2 years and is getting plenty of propane. I burns for 5-10 seconds and goes out. The blinking red light on the circuit board is on whether the unit is running or not.
  • 68 Answers
That is a flame failure check flame rod for carbon build up or qualified technician check it
Posted on Aug 12, 2010
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
Tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
on Dec 01, 2009 | Rheem Tankless water heater for 1-2...
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Jul 31, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
Paloma (Rheem) tankless water heater 7.4 gpm 199,000 btu outdoor unit. Red light is blinking on pc board. unit fires up for approx 2 seconds then shuts off, then cycles once more for 2 seconds and shuts...
i think your flame sensor is bad but you will need to confirm that with rheem i am unsure what the c7 is for but code 12 is flame failure and there could be carbon build up on the flame rod...
Aug 06, 2010 | Rheem Tankless Hot Water Heater...
I am having the same problem as posted by jek01 on Aug 1, my Rheem Tankless Hot Water Heater is not powering off, after two years of use with no issues. I also have to turn the breaker off and wait a short...
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike
jzklipper@aol.com
Oct 11, 2009 | Rheem Tankless Hot Water Heater...
Error code 76 C4 heater shuts off every 5 mins while in shower
Mike//
jzklipper@aol.com
Oct 01, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
397 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
