Question about Razor E300 Scooter
I installed a new battery that is working fine but the motor has no power dwhen you sit on it. /what could be the problem?
  • 699 Answers
If you put in a new battery that has been fully conditioned and charged, then the most likely problem would be the electronic speed controller module which controls the voltage/current to the motor.
Posted on Aug 05, 2010
My ford f150 has a new battery and starts fine all day untill it sits all night then its dead
Someone will need to pull the fuses and disconnect the major electrical components until you find the power drain. You use a meter or test light to watch the battery voltage. It could be anything from a stuck relay, to a short in the wiring.
Feb 05, 2014 | Cars & Trucks
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
I recently replaced the battery in my 2001 Jetta TDI; it started up fine this morning, but after sitting for about 2 hours, it refuses to turn over. It cranks very hard and all the lights come on, so it...
Check, clean and tight correctly the battery leads. If the problem still occurs remove the electrical starter motor out from the engine, repair it (change carbon brushes, bearings, ...) and install it back in place. Then test the engine. It should cranking & start immediately.
Good Luck!
May 15, 2011 | 2001 Volkswagen Jetta TDI
My truck has been hard to start since I have not been driving it every day....it turns over but smells like fuel and and then barely turns over, like the battery is dead, but it has a new battery....and...
You will probably find this problem intermittent.
Check connection and security of the Main Power cable between the Battery and the Starter Motor,
a Good Ground on the stater motor, and the same on the Starter Solenoid connection wire that originates on the Key start and runs thro' the Starter Relay in the Main Fuse/Power contol box.
After doing all of this the problem still persists, Take off the Starter Motor and have it tested at Autozone, or Checker Auto, FOC, and they will advise.
If Starter has reached its sell by date, then you only have to install the new Warrantied unit.
Regards,David
Nov 29, 2010 | 1997 Chevrolet K2500
I have a meade lx200gps 10" scope. The ra up is not responing. the down is working only. After initializing and fining north the auto star says stalled motor.
Do a calibrate motors and make sure you are using a separate 12 volt power pack or BRAND NEW internal batteries. All goto scopes work better with smooth, regulated power. The internal batteries will NOT work well for very long.
The Calibrate motors routine adjusts the motors for the power supply being used.
Oct 10, 2010 | Meade LX200GPS Telescope
Just installed a new battery and I have no power,
hi...
1.As you changed the battery and the volts are fine the problem lies with the wires connecting the starting motor.there may some cut in the wire which prevents the power goin to the started motor.
2.please check the fuse for the starter motor which might have blownout.
3.there may be some junction box/relay through which the power goes to the starter motor. this might have burnt out or damaged so please chekc this also
4.check the terminals connecting the battery and the motor also,
if my answer was usefull to you please rate me
Jul 14, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
My car stereo won't stay powered on.....
your constant power is not working only your ignition power is
Mar 31, 2010 | Car Audio & Video
Install new HD, plug into wall, no lights come on.
Are you sure the HD was installed correctly? The pins not mating properly might be the cause of the problem.
Make sure the power supply is working. Look at the brick (the box on the cord), it may have a light (an LED).
Dec 14, 2009 | Compaq Presario M2000 Notebook
Acer Aspire 5050 I bought a new battery . My laptop works fine on Ac power but when I installed the battery it shuts off immediately
Try setting it up to charge but not turning the system on and let it sit overnight before attempting to boot again. The battery pack may just be in an uncharged condition or even faulty; like everything else today, it was probably made in China.
Nov 10, 2009 | Acer Computers & Internet
Everything works great..However periodicaly radio wont work than battery dead after sitting for sometime.If i pull audio fuse [thats not blown]and re install fuse radio is fine and battery stays...
the radio is pulling down the battery, check to make sure it is install properlt, also make sure your battery is not weak, because remember the radio draws power at all time, to keep the time and your preset radio station. so check the battery for proper strenght first please.
Jul 31, 2009 | Hyundai Santa Fe Cars & Trucks
Razor E300 Scooter Logo
344 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
