Question about Dishwashers
About once a week the dishwasher leaks water on the floor.
  • 135 Answers
Try using less soap. You can also run a cycle with about 5-6 cups of white vinegar with no soap or dishes to clean out soap residue.
Posted on Apr 26, 2008
While on vacation our house had been checked at one week later &again 2 weeks later, @ 3 weeks check, floor in front of dish washer & entire kitchen had standing water , as DW door was opened...
Take a long shot. Say your mains leak a little, quite possible, and you machine's inlet solenoid valve leaks a bit, say about a litre a day - you probably would not notice it during the normal course of events, in a week it would leak about 7 litres into the machine, in the second week it would have about 14 litres in it, about at the level of the door and not seen by the house visitor. The next week it would leak another 7 litres - all over the floor. Now it would be noticed?
Mar 07, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Bosch dishwasher is not draining water and thus leaking on the floor. It is 7 yrs old but only has been used for 3 yrs as I was away. It was run weekly in my absence. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Sep 07, 2010 | Dishwashers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
May 15, 2010 | Dishwashers
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
Why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I think your problem is in the garbage disposal unit. There is a knock-out seal in the outlet on the disposal unit where the dishwasher drain tube attaches. If you don't remove the knock-out then there is nowhere for the dishwasher water to go, and it will spill out onto the floor.
Apr 05, 2009 | Dishwashers
Bosch SHU4322 Dishwasher leaks in the door
Detergent dispenser gasket or faulty air vent.
Feb 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher leaked water once due to an outlet block, then won't start
It obviously has leaked water on the connections underneath, Lean the dishwasher back and see if any water comes out the bottom, then leave it standing for about a week to dry out and hopefully it should be ok.
Nov 26, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Sprung leak when dishwasher was off
could be the valve but more likely is the fill hose itself. pull it out, turn on the water and check the hose carefully especially at the ends wher it joins onto the tap and the machine
Apr 08, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
