Question about Dell OptiPlex GX260 PC Desktop
My Pc is unable to read any cd . there is no cd rom drive icon on my computer.
  • 570 Answers
Please just follow the below steps and fix your problem.
1. Click Start, then Run, then enter REGEDIT to open the Registry Editor
2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right-hand pane, click ONCE to select the Upper Filters entry
5. Make sure the Upper Filters entry is highlighted, press Delete, then Yes.
6. In the right-hand pane, click ONCE to select the Lower Filters entry
7. Make sure the Lower Filters entry is highlighted, press Delete, then Yes.
8. Close the Registry Editor by clicking File, Exit
Please rate me if this solution works for you
Thanks......Have a great time.
Posted on Aug 05, 2010
3 Suggested Answers
  • 43 Answers
SOURCE: I have lost all icons on desktop, cd rom not
Sounds like your hard drive failed. Memory is cheap, so it's not an expensive fix and easy to do yourself with minimal skills. Once you open the case, there should be 4 screws holding the HDD in place, one fat ribbon type cable and one connector with 3 or 4 wires (power). You can just pop a new HDD in and reconnect and use your software disks to reload the operating system. Most computer repair shops can get the data off of your old drive and load it onto your new one.
By the way, you wouldn't happen to be a Limewire user would you? There seems to be a new trend connecting HDD failure and Limewire use. This is not yet proven but being investigated. It is likely not Limewire, but malware attached to downloaded media.
Posted on Oct 06, 2009
sherbazmoham
  • 62 Answers
SOURCE: my computer is unable to read any cd. Moreover
Check if you can find the CD drive in Device manager. If not verify if the drive is properly connected to the cable. If its still not working, try replacing the drive with a new one
Regards
Sherbaz
Posted on Aug 07, 2010
Remove cdrom drive
Removing the cd rom drive will not make your computer start up. Or are you saying the cd rom drive will not start up? CD rom drives are very sensitive on the disks they read. Most of them have a problem reading some of the discs that someone created on another computer. Make sure you're trying to read store bought discs.
Removing the cdrom drive is very simple. Turn the laptop over and you will normally see a screw with the icon of a circular cd on it. remove that screw then you can grab the cd rom unit by the door and pull it outl
Mar 19, 2012 | HEWLETT-PACKARD Pavilion dv7-1247cl...
I have had an LG dvd burner(GH22NP20) for quite a while now, recently it has been unable to read any cd-roms. It reads dvd-roms though..... It will load cd-roms outside of windows so I know the drive is...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Jan 26, 2011 | LG 22x8x22x DVD?±RW DL IDE Drive Black...
My computer is unable to read any cd. Moreover there is no Cd drive icon in my computer. Therefore while I insert any cd in my cd rom drive ,the cd rotates however there is no image or sound from the cd.
Regards
Sherbaz
Aug 05, 2010 | Dell OptiPlex GX260 PC Desktop
PC will not read CD's on DVD drives
my acer 4520 cd rom is not working well when i press cd roms butten its not *** out & also in my computer its tht cd rom icon is not showing so plz give me the solution asap....
Jun 23, 2009 | Acer (91.AB264.001) CD-ROM Drive
Dvd/cd rom won't load disks
hi this seems like a software problem, all you need to do is install the driver of the dvd rom, if you are unable to do this simply restore your laptop to its factory defaults, this may restore your dvd rom drive, it will tell you how in the laptop manual
Mar 28, 2009 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Drive will not read cd rom, reads dvd and audio
CD rom drive is dead!
Time to go out and buy a new one. Rough cost is anywhere for a DVD BURNER is $25 - $40.
DVD burner are now the mainstream drives replacing CD roms.
But if you can still get a replacement CD rom from a computer in town should be cheaper than a DVD burner.
DVD burner can read and write DVD's and CD's.
Aug 14, 2008 | Pioneer Computers & Internet
Does not read cd's
the cd you inserted was not compatible with your cd rom. inorder to read all cds you must use cd roms that supports up 60x speed your only have 24x speed thats y it cant read cds that has above 24x.
Jan 21, 2008 | NEC CD-2800D (cd2800d) 24x CD-ROM Drive
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Connection Problems
If you have other Optical Drive in your computer like a CDwriter then installed it where that LG 52x CDROM drive. Observe if the same problem occur after 2 or 3 hours. Try connecting the CDROM drive to the IDE ports (Secondary IDE port) like setting its jumper to Master. Ensure that the connection to its power supply is firm. Change the setting of your POWER OPTIONS which is under the CONTROL PANEL and change the setting for TURN-OFF HARD DISK to NEVER.
Apr 08, 2007 | LG (GCR-8523BB) Internal 52x CD-ROM Drive
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
