i realize it is probably a brightness or a backscreen problem, but if it is dark, how am i supposed to navigate the controls? is there a way to do it from a connected computer?
-   I have the same problem but don't have any pod adapters to attach etc... I must have only used it a few times & not for 4 months or so. The battery is fully charged and I can just see the darkness of the icons etc... Please help, any ideas? I have played with the battery latch, but no luck. What do I do now? I refuse to pay for Archos to repair it after so little use. Thanks - Ian. -   ianhatswell
Dec 25, 2008
-   My ARCHOS AV700 has been 'rested' for over 6 months and when I power it on, all I get is a dark screen.I know all the files are there as when I connect the USB cable to my pc, I can see the various files. Any ideas?
-   Rog8
Dec 06, 2008
-   Same as above, no usage for some time, and the screen is dark. All the rest is ok.
-   haero
Dec 03, 2008
-   My Archos has a dark sreen after laying up for 2 months. I can just about read it by shining a torch on the screen-   Steve_Jervis
Nov 27, 2008
-   After 6 months "rest" I just pulled my 700 out of the drawer and the screen is almost completely dark.
I tried resolving my dark screen issue using Solution #1. I had the TVPod attached and removed the battery three times. On the third time the screen came back to life also! Thank you and good luck.
Managed to resolve my dark screen issue. It is a little weird and not sure which combination actually got it going but it works. I firstly connected the TV POD unit to the AV700 and used the remote and no joy. With the TV POD unit still connected, I fiddled with the battery latch switch a few times and VOILA! - the screen came back to life and all is now good. I hope it is as easy as that for all of you....
My archos power adapter has stopped working and i am having trouble trying to get an replacement. My...
(More)
My archos power adapter has stopped working and i am having trouble trying to get an replacement. My archos is the av700.
I have an AV-700 that works fine, but when you turn off, the hard drive keeps hunting and runs the...
(More)
I have an AV-700 that works fine, but when you turn off, the hard drive keeps hunting and runs the battery down quickly, reset did not work. Andy
im using archos av7oo.cant accessed anything.once its played on,you cant even go to music videos nor...
(More)
im using archos av7oo.cant accessed anything.once its played on,you cant even go to music videos nor any movies coz once d player started downloading it,its just automatically shutting down.i even consulted a technician regarding it and they even reformat it over and over again yet unfortunately its no good at all.we came to conclude that the main problem was the hard drive itself..kindly help us regarding this matter. P.S...is there a Archos service or repair center here in the philippines?need ur advice asap.Godspeed!
