Question about Transcend Computers & Internet
In my pen drive recycler and etc virouses are entered if i plug it in my computer my computer is slow or inhang position thats why i cant use my pen derive in computer and in computer "it does not sufficient to formate" like these options are shown
    Problem Solver:
  • 28 Answers
  1. scan it first
  2. try unlocker software
Posted on Aug 05, 2010
Processing is very slow
it seems your computer or the pen drive or both virus infected.
press win button + R - type cmd - type H: (if your pen drive recognized as H or (whatever your pen drive's drive letter)
then carefully type the following without bracket [attrib -r -s -h *.* /s /d]
press enter. now check your pen drive. if you could not, inform me i'll give images with explanation
Nov 23, 2013 | Sony VAIO Computers & Internet
Very slow transfer to Kingston 8GB datatraveler
HI,
- Check if your PC is running at its maximum efficiency
- Close all side processes that are not of any use to you. This can be done by pressing :Ctrl+Shift+Esc and then going to processes. In there only close the processes that are under your user name and are of no use. NOTE: DON'T CLOSE "EXPLORER.EXE". This will free a sizeable amount of your RAM, making your PC generally faster.
- While copying anything, avoid multi-tasking as that will simply slow down your PC, causing a delay in the copying.
IF NONE OF THIS WORKS, then create a back-up of all the software in your Pen-Drive and then format it.
This should just about do it.
If still the problem persists, go to your dealer- your pen-drive must be in its warranty period.
Sep 30, 2008 | Electronics - Others
Have TRANSCEND D33193 4GB pendrive when i plugged it in my PC it is not detected , some one please help me.........
all pen drives are like jokers of a pack of cards....they behave very funny when you need them....
one of the most stupid inventions of the computer world....are these pen drives....
they are very much likely to carry virus from PC to PC....unlike the CD / DVD that cant be written without using a write program.....like Nero etc....CD/DVD disk are write protected by default....but the USB sticks can be used by drag and drop files.....so the virus get in without the user doing anything....
also when you thingk that you are buying a 4 GB pen drive, some times the dulicate are not exactly 4 GB...they are just 1 GB...and show 4GB as capacity...after using for some time they show their real face(1GB) and the drive becomes useless....
To tell you the fac many mfg are packing more and more space into a pen drive...like 32 GB, etc...but actually the physical capacilty is only 2 GB but expanded to 8 Gb / 12 / 16 GB using a compress program....after few uses....that becomes usless.....
Apr 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't format my pen drive how can I format my pen drive
there may be a small sliding switch that could be set to "Protect" ie the drive is protected from formatting, or deleting or even adding files.
Change the position and then re-insert the drive into your computers USB port. Go to My Computer, right click the pen drive and select "Format"
FAT32 format will give you a drive that is readable and compatible with Windows 95, Win98, Win2000, XP etc.
You can format in NTFS format but it will only be readable by Win2000,XP or Vista or Win7.
Cheers,
Steve
Jun 30, 2010 | Computers & Internet
Write protection on 8 gb pen drive
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); 4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
May 29, 2010 | Transcend (589307) Media
Slow, stalls, freezes up
If your hard drive is too full, then your computer is going to perform slower. Delete old files which are not required.
Remove programs that you are no longer using. Delete temporary files.
Empty your recycle bin. Right click on Recycle Bin. Click Empty Recycle Bin>Yes.
Run an error check on your computer. The error check can remove errors that slow down your computer. If you are using Windows, you can do this by clicking Start>My Computer. Right click on your hard drive (typically c:) and then select Properties. Click the Tools tab>Check Now and then Start.
Clean up your registry. You can purchase software that will fix any registry errors on your computer.
Perform this computer maintenance on a weekly basis.
Apr 24, 2010 | Dell Inspiron 1501 Notebook
Hard disk drive heeling
There is a virous that infect your system.Scan the system with a latest antevirous and delete the virous.If it not possible to remove.formate the entire system.
Jun 26, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
My internet is moving too slow because I have too much programs to delete.
your internet is slow not for progame if you computer slow then you can say but net slow
did you scan you may be you got virous
clean cookies
do you have uptodate virous scan programe
scan your copmter on web free scan virous
Aug 15, 2008 | Gateway Computers & Internet
Delete RECYCLER folder
Right click the recycle bin in 'my computer' or on the desktop and goto the properties. You may then configure the recycle bin for each drive or turn it off altogether. Once it is turned off for a particular drive you may remove the recycler folder (ignore the warning) it will not re-appear again when you delete files.
Oct 02, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
35 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
