Question about Sony PlayStation Portable (PSP) Console
Broken XO Pad/Power Switch
Before anyone says go get it fixed i was wondering if there was anything i could do myself. My power switch broke a few weeks ago but today i turned it on without the switch (from behind the screen) and it worked, but the light never turned on and i couldnt use the XO buttons. This probably means i should get it replaced huh...
    Problem Solver:
  • 6 Answers
No, you should wait till pigs fly.(Sarcasme)
Posted on May 03, 2008
  • 4 more comments
  • Pannopap May 03, 2008
    Yeah what I said!
    ....................................................................................................................................(No comment)
    Fix it before it`s to late!
    Save the handheld,save the world!
    Knock knock, is Eltrish home? Get the thing fixed!
    END the pain and agany already, get the baby to the hospital!
How do i fix power button switch on my wireless bluetooth headset? it the LG tone HBS-700
It is possible you may have broken the power switch off of the circuit board. To find out, you will need to open the earpiece and inspect it. Here is a video on how to open the earpiece LG Tone HBS700 730 repair mod and upgrade. If it has broken off, you may be able to solder it back on to the circuit board. If it is beyond repair, you could purchase a broken earpiece for cheap and use this video to repair it.
I hope this helps.
Feb 13, 2015 | LG HBS-700 Bluetooth Headset
Power when door open only wfw9150ww, other problems???
check for a short in the door switch,use a new switch and try versing polarity -sometimes works even if its wrong
Nov 06, 2013 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
HP deskjet 3054 broken power button
Hp's usually have a micro switch underneath the power button. You probably just broke a support arm or type device. You might be able to super glue the piece back together and make it work. In my experience, this usually works about 40 percent of the time. Usually by pushing to ******* the switch to break the plastic you could have possibly damaged the small micro switch. My best suggestion is take it apart and try the super glue fix first. Good Luck!!
Jun 13, 2012 | HP Deskjet F2210 InkJet Printer
Broken Master Lock for Power Windows in 89 Toyota Landcruiser
Looks like I just described the solution to the same problem here.
http://www.fixya.com/cars/t2178229-son_broke_power_window_lock_in_89_toyota
First thing you need to do is get a replacement part from toyota or a wreckers.
Jun 06, 2009 | 1992 Geo Storm
2004 Jeep Cherokee Laredo Power Seat Lent Jeep to my son, next morning went to go to work, and noticed the power seat is rocking back and forth. The power button will slightly move back and forth but will...
Rocking tells me that something in the mechanism is broken. failure to move with switch could mean that either what broke or something else has jammed the track. If you are good at this kind of thing, remove seat (4 bolts & unplug harness) and flip it over if you can't see anything installed.
It could have broken because it was ready to break but that's why I don't loan my stuff to anyone! (when something breaks then it's my fault) If parts turn out to be really expensive, you can likely find a working seat in a junkyard for pretty cheap.
good luck with it...hope its something small & easy!
Mar 16, 2009 | 2004 Jeep Grand Cherokee
Broken power switch
Look on the well known auction sites. Some are selling the switch. Ask them if they could also replace it for you. I could do it for you but I'm in Europe, so a little to far
Nov 17, 2008 | Nintendo DS Lite Console
Honeywell manual fan switch broken
The fan limit switch is basically like a thermostat. When the plenum heats up to a certain degree it turns on the fan to start heating your house, and turns off when the fan off when the plenum gets around 80-90 degrees so that you’re not pumping cold air in to house. It also acts as a safety switch if the fan does not come on the plenum will get way to hot so this fan limit will kick the furnace off before that happens. As far as that little white button it should always be on auto you can try to use needle nose pliers to get it back into the auto position, or if you have the broken piece you can try to glue it back on. The white button goes in and out it does not turn or anything just make sure you turn the power off first and if u can’t fix it replace.
Oct 13, 2008 | Honeywell L4064B2236 Fan/Limit Control...
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
In need of Parts for an HK 700 Series amp/tuner/preamp..Having trouble
Hi Randy, I tried to have a chat with you earlier. Couldnt work for some reason? What did you find?
regards
Graeme
Apr 08, 2008 | Audio Players & Recorders
Stuck in camera mode, little switch fell off.
Has anyone tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
page number 114 of your manual. tell me if this works
Oct 20, 2007 | Canon PowerShot A540 Digital Camera
Sony PlayStation Portable (PSP) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
