Question about HP Compaq Evo D310 PC Desktop
HP Compaq Evo D310 Desktop. After connecting the mains supply to the desktop and swithing the power on, nothing happens when pressing the power button on the front of the unit. I notice there is a small red switch next to the power input does this have to be switched!
  • joecoolvette
    joecoolvette Aug 05, 2010
    Some Power Supply's have an On/Off rocker switch. I for On, and O for Off. Power Supply's generally have a Voltage Selection slide switch. The Voltage selection is either 110, or 220. The switch is slid, until the appropriate voltage is showing. (Computer unplugged from power before doing so) USA uses 110. Most of Europe 220. Newer Power Supply's of better quality, do not have a Voltage Selection slide switch. Circuitry inside automatically detects what the Voltage is, when the Power Supply is plugged in.
  • HP Master
  • 11,800 Answers
That switch is there to select between European and US voltage - if the pc has worked before then leave it as it is. Change it to the wrong setting and the power source will be fried.
Your pc doesn't start because you have a hardware fault.  Disconnect the data cable from the hard disk and try again. Next you must test the power source itself , outside of the pc - take it out then connect the green wire from the big connector to the black wire next to it; if the fan of the source doesn't start then it's fried, replace it. If it does then you must try the other components. If you haven't done that before , or if you don't have other components to swap for testing ,  then it's time to take it to a shop, nothing more you can do to it
Posted on Aug 06, 2010
I have a compaq evo w6000, my problem is that on starting it it oly blinks red and no activity at all but when the power supply is checked all the red green blue yellow black cables are live with...
ffsffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
Mar 23, 2011 | HP Compaq Evo W6000 PC Desktop
Sreen resolution of an hp compaq d310 intel .what drivers must i get
You need the Display and Graphics drivers. Click here to go the download page. It is a good idea to update all the other drivers as well if not done already.
Sep 25, 2010 | HP Compaq Evo D310 PC Desktop
Motherboard drivers download
look at the screen when unit boots up. There will be a BIOS manufacture, along with a set of long numbers. Sometimes they appear in the lower left of the screen.Copy down that info and go to this site.
http://www.motherboards.org/search.html
There you can enter your info and it will tell you who made the motherboard
Apr 26, 2010 | Compaq (283983-001) Motherboard
Missing Multimedia Audio Controller (device manager) I'm running windows xp ver 5.1 sp2 Compaq 0804h motherboard Need a Multimedia Audio Controller for Evo Compaq d310 PC Microtower
Best place to look is the Compaq website. If you cannot find it there, you could try using a driver finder program to locate the right driver for your sound card. Those programs will identify the hardware by device id and use that together with the Windows info to get a matching driver.
Apr 23, 2010 | HP Compaq Evo D310 PC Desktop
Hi. I have a compaq 0804h and I can't find drivers for the pci conrtoller. Could you help me?
pci drivers r available from the products u purchase for ur slot. no need to install pci drivers without any card in your pci slot,
Jan 22, 2010 | HP Compaq Evo D310 PC Desktop
How to fix error 512 for evo d310 I replace chassis, rear chassis, or front chassis fan but still error I wont to fix it not show any error thank
Error 512 is a common Windows error. Error 512 is usually caused by missing system files, wrong system settings or a corrupted registry file. Run a registry scan to check for registry errors & other system problems. 90% of the time this will fix the cause of the error.
Optimize PC programs might do the trick, some are free to download.
Jan 13, 2010 | HP Compaq Evo D310 PC Desktop
I need a manual for Compaq Evo
Please download the manual from the below given URL, I hope this helps you know your system.
http://www.manualshark.org/p/hewlett-packard-28/hewlett-packard-compaq-evo-d310-micro-desktop-26933/
Sep 22, 2009 | Compaq Evo D500 PC Desktop
Need bios update
you need to dowload bios updates from hp:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=97106&taskId=135&prodTypeId=12454&prodSeriesId=96284&lang=en&cc=us
Mar 06, 2009 | Compaq D310 (287944-CTO-4) PC Desktop
Motherboard drivers missing for internet connections
Need VGA and Ethernet drivers for Compaq Evo D310.
Jun 26, 2008 | Compaq Evo D310v PC Desktop
HP Compaq Evo D310 PC Desktop Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
