Question about Electrolux 24 in. ESI6220X Free-standing Dishwasher
Our Electrolux ASL 6229 VI will not drain. It makes a continuous flashing indicator noise after being turned on for about 5 mins. We have cleaned the filter but this not improved the situation.
4 Suggested Answers
  • 905 Answers
SOURCE: I have an electrolux icon
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Posted on Dec 24, 2008
jillwillis
SOURCE: Hi, My Electrolux twin clean vacuum has both red
Try taking the twin filters outside - also take a dustpan brush and tap the filters gently on the bottom, then brush the dust away as it comes out. This can take quite some time, and you will find that LOTS of compacted dust will come out!
Posted on Apr 24, 2011
rickead1
  • 1998 Answers
SOURCE: Hi, I have an Electrolux EWF 1074 front loader.
Go back and check your connections. If you had the machine working previously and none of these issues were there before you cleaned out the drain area of the unit then your first step would be to check the connection to the pump as well as your connections going from the control to the door area as well. If after you have checked all your connections to the pump the door lock assembly, the control and the touch pad the unit is still doing the same thing then message me back. Before you do any of the checking of connections in the unit first hold down delay and extra rinse buttons together for 3-5 seconds. This usually will unlock the control if the control is locked on the unit. Also if the delay and extra rinse and the checking of your connections does not solve your issue then also message me back with the number of times the pause button is flashing and how often it flashes as well. If you have any further questions message me those back as well. I await your reply Thanks again Rick
Posted on Jul 18, 2011
How do I turn off the beeping noise on the Electrolux 7kg Time Manager washing machine the 5kg Electrolux Sensor Dryer? The beeping noises indicating a cycle has finished are very loud. Please help!
The acoustic signals operate when:
• The programme is completed.
• The appliance has a malfunction.
To deactivate/activate the acoustic signals, press "Drying level" and "Prewash" button at the same time for 6 seconds.
If you deactivate the acoustic signals, they continue operate when the appliance has a malfunction.
Dado
Mar 06, 2016 | Electrolux Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Hi i have an electrolux ewf 1087 that wont start everytime i press start it goes straight to drain, like from 2 hrs, it will go down to drain for 2 seconds then down to 0, if you turn it off then on again...
Here are two reset procedures for the control panel that might get your machine working again:
  1. Unplug the machine for about 1 minute. Plug it back in and check the machine's operation. If this doesn't work, try the next reset procedure.
or
  1. Turn the dial to Off.
  2. Press and hold the start/pause button and the nearest option button. While holding them down, turn the dial one notch clockwise.
  3. The machine will beep or flash, when it does let go of the buttons.
  4. After you release the buttons, turn the dial slowly, stopping at each click until you get to "off".
  5. Now, turn the dial to any setting, then turn to off.
  6. Check the machine's operation.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 18, 2011 | Electrolux Washing Machines
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
It starts off ok but 5 mins in to the cycle (any cycle)all the lights start flashing and it just makes a sloshing noise but the drum is still.... .it an indesit wia111
Check the drain pump they haave a catch sleeve inside the drain line before the drain pump. Remove the lower front panel to access the pump and remove the large hose from the drum. Inside the hose is the sleeve, take out the sleeve and clean it.
Dec 11, 2008 | Indesit W 123 Front Load Washer
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Electrolux 24 in. ESI6220X Free-standing Dishwasher Logo
29 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
