Question about Nikon COOLPIX S200 Digital Camera
When turn on my nikon coolpix s200 the lens zooms in and out for about 30secs before the message 'lens error' comes on the screen
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 02, 2012
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
jackboy
  • 2985 Answers
SOURCE: Driver Installed
Diditial camera do not need 'drivers' for PC's operating with WinME/2000/XP/Vista
Windows does it all
Posted on Jun 01, 2008
SOURCE: Nikon Coolpix 5700 - Lens Error
sweet. this helped. I was just too lazy to find out on my own. lol. easy solution.
Posted on Jul 09, 2008
SOURCE: Nikon S200 Lens stuck inside
I had the same issue with my S210, so after reading other people's advice to send it in to Nikon and since that was going to probably cost me as much as the camera itself I figured it wouldn't hurt to try a little something. The lens on mine was a hair off center or had been pushed in on one side (barely - looking at yours you may be able to tell which side) - mine was in my purse also. So, I took my handy dandy skinny prying instrument (normal kitchen butter knife) took the battery out to make it try to open again, then when I popped the battery in as the lens tried to push out I pried the side I thought was a little lower back towards center...I heard a little pop and it worked! The lens came all of the way out and it's all good.
So, use gentle hands and try if you want, but don't think I warranty this!
Posted on Mar 07, 2009
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Error message ''Lens error'' on nikon coolpix digital camera
Try cleaning any grit out of the lens mechanism with compressed air and a little wiggling of the lens. If that doesn't do it, the camera needs servicing.
Nov 15, 2009 | Nikon Coolpix S210 Digital Camera
Nikon coolpix camera shows lens failure when switched on, lens will not come out
     According to the symptom the problem is in lens assembly, this problem arries when the zoom motor start malfunction. You have to replace the lens assembly. For this please contact any  expert nearby or visit
 www.partstore.com
Thanks for using fixya.
Oct 31, 2009 | Nikon COOLPIX S200 Digital Camera
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
Coolpix S200 lens error message
A piece of sand had worked it's way into your lens machinery. Replace the whole lens, or find the grain of sand in a gear somewhere.
Nov 13, 2008 | Nikon COOLPIX S200 Digital Camera
Blurry picture nikon s200
It doesn't say lens error? but it won't focus? it is probably the same as the other people who do have lens error displayed on the screen, the lens is broken is what the repair company told me about my s200 when i told me lens error
Jul 22, 2008 | Nikon COOLPIX S200 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
90 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
