Nokia 6230 Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone switches off when i make or receive calls
Anonymous
Level 2:
New Friend:
  • Expert 103 Answers
  • Posted on Aug 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
103
Questions
0
Helped
13867
Points
340
Please go to phone setting and search the phone restore setting press button 12345 ok and then turn off after turn on and use it
2answers
I can't send text messages from nokia 5800
Just Switch off and switch on your mobile. if the problem remain, contact your network operator(customer care).
Thank you
My phone is switching on with blank scream
When the phone turns on with the blank screen, can you receive or make calls?
If you can receive and make calls, the fault should be from the screen. Maybe it is not well connected to the board or the screen is bad.
But if you cannot receive or make calls, then I think your phone has a virus. The virus might have corrupted the phone software files, thereby, not allow the phone boot. In this case, you need to flash the phone.
Best wishes.
1helpful
2answers
I can call out on my phone but incoming calls are not getting through.
When calls come through , receive and reject signs come up , press green to receive then nothing???
Key pad got locked of samsung c100
Call your phone company, they have the master code to unlock the phone. They would be more than happy to assist you with this problem, and they are the only ones who are actually able to help you :) Hope I could be of assistance!
4helpful
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Brother intellifax 775
Did you get DSL service? You don't need anything except an ANALOG phone line.
Making and receiving calls
sound like your mic has died but check this first.
Take off the battery and squeeze the bottom of the phone together if the screws raise up then rescrew them in and that may solve the prob.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
