Question about Intel Desktop Board D845WN Motherboard
Water in mainboard - Intel Desktop Board D845WN Motherboard
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
Make sure you don't turn it on. Turning on the motherboard in wet condition will cause damage to it.
The best thing to do is dry out the Motherboard; you can use some tissue papers to gently wipe the water on the board and then you can use some hair drier or blower to dry the Mother board(Make sure you remove all the components and do this separately). Once it is dried let them all dry further for 24-48 hours and once you think it is completely dried up re-fix the components together and try to boot up.
In most cases this works. Make sure your ram slots, pci slots, etc are completely dried up (this is the reason why we need to remove all the components before drying up).
Hope this helps.
Best Regards
NextDoorNerd
Posted on Aug 05, 2010
    President:
  • 548 Answers
Replace the motherboard. There are 90% chances that your motherboard is toast.
Cheers
Cimbali m3 problem with mainboard
Marion boards are expensive so before grabbing anther it's best to check every aspect of the machine and board. Water damage, steam leaks caused shorts, loose plugs, Rodent damage, etc. Way to many things to go bad before a board replacement. Always do a PROM reset to go back to basic settings. Pulling board also replica all connections. You take a chance of burning out 2nd board. The display goes bad as it's always near water and steam. Do a visual inspection of board foe burns, cracks, water stains, coffee trails. Check programming to see if you can manually activated each item. Boards do go out but usually with a bang. Keep looking. Mark
Mar 09, 2014 | Espresso RMI La Cimbali Espresso Machine
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Motherboard powerlight blinks
How about reassembling the laptop, and let us know?
(Bet you already though about that a few seconds after you posted, huh?)
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=1839150&MEID=CD0E1321-41D2-40AE-B3A3-4B2EE3E7F477
Post back in a Comment.
Regards,
joecoolvette
Jan 06, 2013 | HP Compaq NC8430 Motherboard - 416397-001...
Dropped off a glas of water on my toshiba laptop and now it's not longer turning on
Given that your laptop is not water resistant, the water probably leaked onto the mainboard, fried it thus rendering it unusable. Replace any of the fried part (usually the mainboard is one-piece, so sending it to advance circuit technician is advised).
Dec 14, 2011 | Toshiba Satellite P35-S611 Notebook
How to maintain short circuit mobile by water
First thing to do is don't ever try to power your phone On or even plugging the charger In,obviously this will be the affect the mainboard that leads to shorting the circuit board.Now remove the battery first and unscrew the screw shown on the sides or corner,then release the side clips ,lift up the mainboard gently and release the flex coonector,its time to clean the mainboard using a rust solution or a lacquer thinner and a toothbrush,gently scrub the entire board and make it dry using a hair blower and a dry cloth as well. Now its time to assemble the the phone.
Jul 29, 2011 | Samsung SGH-E370 Cellular Phone
I spilled a teaspoon of water on my acer aspire netbook and I wiped up the water and shut down the computer. This was two hours ago. I used canned air to make sure I dried out the water. I tried turning...
first I would let it dry for day or two.
This is most probably due to your mainboard.
Is there any beep tone? Or any sign of activity on your monitor?
You could test if by taking out your RAMs for example. If you turn it on then, you should hear a beep code. If you dont, it is your mainboard..
Jan 13, 2011 | Acer NSK8458AN Keyboard
My camera was in sea water and damage mainboard. Can & brought new mainboard?
That's not all that was damaged. Salt water is very corrosive and is still eating at the other parts of your camera not to mention getting in between the lens elements.
Jan 07, 2011 | Nikon COOLPIX L101 Digital Camera
When i switch on it does nothing ,just a noise that is pumping water out but there is no water and the machine do not start
clean first the filter of the water inlet.
and if your a techy check the solenoid valve
"mechanical and Electrical"
also check if there is voltage supply in the connector of the solenoid valve if there is no supply the problem is coming from the relay of mainboard
Sep 09, 2009 | Dishwashers
Samsung u600 water damage
Be sure that you don't power on the unit after it was dropped down into water.
Dry it first especially the parts inside must be dry and no water or any wet in the mainboard.
There's a possibility that you can still used your cp, but you have tobe sure for the 2nd time again i say this "the unit should be fully dry".
Regards
-micro
Feb 19, 2008 | Cell Phones
Intel Desktop Board D845WN Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
