Question about Car Audio & Video
Please tell me how to remove a TF 4001 08600-00921 car stereo(casette) from Toyota Corolla 1996?
5 Suggested Answers
  • 651 Answers
SOURCE: Removing Toyota Corolla 1990 Car Stereo
the plastic frame around it should snap out with a flat head screwdriver to get access.
Posted on Dec 19, 2008
  • 4979 Answers
SOURCE: Need to remove a casette tape stereo from 1990
Find your free instructions on this website
http://www.fitaudio.com/
Posted on Sep 24, 2009
  • 4979 Answers
SOURCE: I need to remove a
http://www.fitaudio.com/index.php?CategoryID=12
Posted on Sep 19, 2010
ZJLimited
  • 17970 Answers
SOURCE: need car stereo color codes for 1996 toyota avalon XLS V6
Check this for 1996 Toyota Avalon Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope helps (remember to rate and comment this free answeer).
Posted on Sep 29, 2011
How do i take out my radio from my toyota corrola
The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
    > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
    > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
    To install
    > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
    >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
    > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
Dec 05, 2010 | 1990 Toyota Corolla
My 96 toyota corolla will not start but has power and the battery is good
Tap on the starter as you try and start the engine,if it trys to turn over,then the starter is bad for sure,if it does not,it still can be the starter,remove it and have it checked.If this was helpful,please rate,thank you.
Jun 15, 2010 | 1996 Toyota Corolla
I need to replace the rear stereo speakers in my 2006 Corolla
You have to remove the package tray to access them. once it is removed they are held dow with 4 bolts per speaker
Apr 20, 2010 | 2006 Toyota Corolla
Changing headlight 1996 toyota corolla
there are nuts/bolts behind the grill. remove them.
Sep 18, 2009 | 1996 Toyota Corolla
1996 Toyota Corolla Plastic Trunk Opener Broken
Too Much they are Pretty SELF EXPLANITORY if you are Inclined Mechanicly DIY
Aug 05, 2009 | 1997 Toyota Corolla
Engine removal/replacement
engine removal 1996 corrolla
Mar 26, 2009 | 1996 Toyota Corolla
Request for the wiring diagram for a 1989 UK spec Toyota Corolla Hatchback
Sure. Glad to provide assistance.
89 Corolla radio wiring colours:
Power- Solid GREY -
from the 7.5 amp RADIO fuse
Backup power - BLUE w/YELLOW tracer
from the 10 amp DOME fuse
RF speaker - LIGHT GREEN and BLUE
LF speaker - PINK and VIOLET
RR speaker - RED and WHITE
LR speaker - BLACK and YELLOW
Ground/Earth - BROWN
The graciousness of a FixYa rating would be greatly appreciated.
Jan 19, 2009 | 1989 Toyota Corolla 2 Door
Dec 19, 2008 | 1990 Toyota Corolla
Radio cassette removal from 1996 toyota corolla
HI
I took my car to halfords to have my stereo fitted (also bought stereo from Halfords). they basically had to taken everything out of the middle bit to get to the stereo (All the air vents and control switches etc). It took about an hour to do, but at least you know there is no quick way to steal the radio once it is in. I think it helped that I managed to get a guy that had once been a macanic so he knew what he was doing.
Hope this helps
Aug 28, 2008 | 1996 Toyota Corolla
Car Audio & Video Logo
192 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
