Question about Refrigerators
Samsung fridge/freezer model SRS594HNSS Freezer working fine, fridge not getting cold.
HVACRH20
  • 237 Answers
SOURCE: Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Posted on Feb 27, 2007
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
  • 5 Answers
SOURCE: Samsung Fridge Freezer
Possible bad defrost timer.
Posted on Mar 09, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
SOURCE: fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My fridge is leaking water in the fridge then doesnt stay cold. Freezer is working fine just not fridge.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Samsung Refrigerators
All of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Apr 18, 2009 | Refrigerators
The fridge compartment not getting any cold air.
Well for whatever reason the fridge compartment is now getting cold air again and its all working fine. Have no idea whats gone on with it but is working again hahaha. The only thing that we did was take the back off the freezer, where it houses the fan motor, the motor wasnt quite straight so I straightened it and now its working. Whether that was the problem to begin with I have no idea.
Apr 12, 2009 | Westinghouse Refrigerators
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
