Question about Apple iPod nano
Low Battery My ipod has a message no battery power remains. Please connect to power. I have connected to 2 different power sources and it's not charging.
    Problem Solver:
  • 14 Answers
Well im not sure because im not an expert but let me tell you ive had a big experience with ipod problems ive had it lock ive had it freeze ive had it not turn on so i tried to chrge but i had to hold down play and the middle button and i even had it sticky form chocolate melt on it but #1 make sure you have it properly put in and make sure its not locked like mine um if it is hold down the play and midddle button till somethign happens like a dark apple shows up if that doesnt work your best hope is to bring it into best buy or something
Posted on May 01, 2008
Please wait very low battery
This is, clearly, a battery issue. Try restoring the iPod by following this article "http://support.apple.com/kb/HT1339". If your issue persists, then you might have to send the iPod in. It might cost you, if your iPod isn't within warranty.
Jan 07, 2010 | Apple iPod MA446LL/A MP3 Player
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
Ipod says charged, but when i unplug it it cuts
  1. First thing to do is restore it to factory settings to see if that corrects the problem.
  2. Make sure you’ve installed the latest version of iTunes.
  3. Open iTunes, and then connect your iPod to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod in the Source pane and you will see information about it appear in the Summary tab of the main iTunes window.
  6. Click the Restore button. A window will appear asking "Are you sure you want to restore the iPod "iPod" to its factory settings? All of your songs and other data will be erased."
  7. Click Restore again. (If you're on a Mac, you'll then need to type in your password.)
  8. During stage 1 of the restore, a progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If all else fails and the battery is bad, replace the battery. Here is a video that will show you just how easy it is. No need to pay Apple any more money than you already did to repair it.
http://www.youtube.com/watch?v=2h53otOBTsI
I hope this helps and good luck!
Nov 03, 2009 | Apple iPod MA446LL/A MP3 Player
How can I power on and power off my apple ipod a1136 model?
Generally speaking, if you have connected it to a power source when it has completly drained it should display 'Please Wait, Very Low Battery' (without the backlight). If it does, leave it until that message disappears. Pressing the play button should now wake it. However, If you have been charging it for a while and nothing has been displayed the battery my be dead all together. With the iPod connected press the Select and Menu Buttons together until an Apple symbol appears (non-backlit) it should then startup. If it turns off when disconnected from the power then you have a dead battery. If none of that solve it I offer a repair service at a very low cost.
Dec 13, 2008 | Apple iPod MA446LL/A MP3 Player
New replacement battery won't charge.
What you can try is to connect it to your Desktop computer USB port at the rear of you computer and charge it for 8 hrs atleast..
then try this step once
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
and also try this at last
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
Nov 12, 2008 | Apple iPod MA446LL/A MP3 Player
IPod not charging
your cable might be worn out
Jul 31, 2008 | Apple iPod nano
Hi my ipod it stuck on low
It sounds as though you have a bad battery, need to get it replaced. iTunes will not recognize it until it boots up and connects to your computer. As long as the battery itself remains low, your iPod will not boot up to be seen.
Jul 06, 2008 | Apple iPod MA446LL/A MP3 Player
IPod Battery
You should try using a different USB cable and connecting to a different USB port and seeing if the problem persists. If it does, the problem's probably with the iPod's logic board.
Jan 01, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod battery
Hi all,
Since you guys hav tried many option to charge the ipod... try this out by connecting it ot USB port at the rear of your desktop computer..
also try this out
Nov 30, 2007 | Apple iPod mini 2nd generation MP3 Player
Froze/no charge
It has a very low batteyr voltage therefor your computer cant charge it. Buy a wall charger but you may have to put it on disk mode.
Jan 11, 2007 | Apple iPod mini 2nd generation MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
